Yes thats helpes....
another error....
after i installed the distro....
grub failed to create an bootloader...
Der Bootloader konnte nicht installiert werden. Der Installationsbefehl <pre>grub-install --target=i386-pc --recheck --force /dev/sdb</pre> erzeugte Fehlercode 1.
if i call that command with sudo.... i get this:
╭─garuda@garuda in ~ as 🧙 took 18ms
[🔴] × sudo grub-install --install=i386-pc --recheck --force /dev/sdb
Installing for i386-pc platform.
grub-install: error: cannot open `/usr/lib/grub/i386-pc/i386-pc.mod': No such file or directory.
sudo grub-install
x86_64-efi wird für Ihre Plattform installiert.
installation beendet. Keine Fehler aufgetreten.
╭─sgs@pro in ~ as 🧙 took 1s
🕙 20:32:03
╰─λ sudo update-grub
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found linux image: /boot/vmlinuz-linux-amd-znver3
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-amd-znver3.img
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Found Garuda Linux on /dev/nvme0n1p6
Found Garuda Linux on /dev/nvme0n1p7
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-08-23 17:53:44 | @/.snapshots/692/snapshot | post | re2 |
Found snapshot: 2023-08-23 17:53:44 | @/.snapshots/691/snapshot | pre | pacman -Rns re2 |
Found snapshot: 2023-08-23 17:49:02 | @/.snapshots/690/snapshot | post | libdrm libixion liborcus libreoffice-fresh libreoffice-fresh-de |
Found snapshot: 2023-08-23 17:48:58 | @/.snapshots/689/snapshot | pre | pacman -Su |
Found snapshot: 2023-08-23 10:07:15 | @/.snapshots/688/snapshot | post | git |
Found snapshot: 2023-08-23 10:07:14 | @/.snapshots/687/snapshot | pre | pacman -Su |
Found snapshot: 2023-08-23 01:42:49 | @/.snapshots/686/snapshot | post | fastfetch fwupd nextcloud-client telegram-desktop xfce4-terminal |
Found snapshot: 2023-08-23 01:42:46 | @/.snapshots/685/snapshot | pre | pacman -Su |
Found snapshot: 2023-08-22 11:42:18 | @/.snapshots/684/snapshot | post | libupnp signal-desktop |
Found snapshot: 2023-08-22 11:42:16 | @/.snapshots/683/snapshot | pre | pacman -Su |
Found snapshot: 2023-08-22 08:05:20 | @/.snapshots/682/snapshot | post | fastfetch iana-etc imlib2 librewolf luajit whoogle-git |
Found snapshot: 2023-08-22 08:05:18 | @/.snapshots/681/snapshot | pre | pacman -Su |
Found snapshot: 2023-08-21 09:43:58 | @/.snapshots/680/snapshot | post | gallery-dl |
Found snapshot: 2023-08-21 09:43:58 | @/.snapshots/679/snapshot | pre | pacman -S chaotic-aur/gallery-dl |
Found 14 snapshot(s)
Unmount /tmp/grub-btrfs.Io45NdxLYB .. Success
/usr/bin/grub-probe: Warnung: Unbekannter Gerätetyp nvme0n1.
done
╭─garuda@garuda in ~ as 🧙 took 4ms
╰─λ sudo grub-install
grub-install: error: install device isn't specified.
╭─garuda@garuda in ~ as 🧙 took 62ms
[🔴] × sudo update-grub
/usr/bin/grub-probe: error: failed to get canonical path of `overlay'.
You have a UEFI board but you are booted in legacy mode. Try booting to the live environment in UEFI mode, then you should be able to complete the installation.
Are you using manual partitioning, or something else?
