hi garuda people
how r u all ?
i have this question and i couldn't find an answer for it ,
why every time i start a video in a website such as youtube or other video streaming pages i get an annoying voice like if you say this - tik- but in sharp and loud voice?
is there anyway i can stop this ?
i am on mate garuda latest version.
thanks all.
- Welcome to the forum
- Wrong category - should be "issues and assistance"
- Read the issue template there
Please share output of
As text enclosed in ~~~ here. Like if you have output a
, post
a
Here.
Kernel: 5.19.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=628747ff-bed5-41a4-b877-703bb8c89356 rw rootflags=subvol=@
Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.0 vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20351 v: Lenovo G50-70
serial: <superuser required> Chassis: type: 10 v: Lenovo G50-70
Mobo: LENOVO model: Lancer 5A2 v: NANANANANO DPK
serial: <superuser required> UEFI-[Legacy]: LENOVO v: 9ACN32WW
date: 07/20/2015
ID-1: BAT0 charge: 21.5 Wh (88.5%) condition: 24.3/37.3 Wh (65.2%)
volts: 15.7 min: 14.8 model: Lenovo IdeaPad type: Unknown serial: <filter>
Info: model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 built: 2013-15 process: Intel 22nm family: 6
model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/2700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 800 3: 798
4: 800 bogomips: 19156
vulnerable
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: Lenovo
driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 2
speed: 5 GT/s lanes: 4 link-max: lanes: 8 bus-ID: 03:00.0
chip-ID: 1002:666f class-ID: 0380
Device-3: IMC Networks Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 2-6:4 chip-ID: 13d3:5727 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: marco v: 1.26.0 driver:
X: loaded: modesetting,radeon alternate: fbdev,intel,vesa gpu: i915
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x40ec built: 2013 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.19.10-zen1-1-zen running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 5000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Lenovo Z50-75 driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:b723
Device-1: Realtek RTL8723B Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 2-7:5 chip-ID: 0bda:b728 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 465.76 GiB used: 16.25 GiB (3.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LVM1
scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 16.25 GiB
(3.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 16.25
GiB (3.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 16.25
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 16.25
ID-1: swap-1 type: zram size: 11.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C mobo: N/A gpu: radeon temp: 41.0 C
Processes: 231 Uptime: 8m wakeups: 1 Memory: 11.59 GiB used: 3.11 GiB
(26.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1194 libs: 322
tools: octopi,paru Shell: Bash v: 5.1.16 running-in: mate-terminal
inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2022-09-25
Last full system update: 2022-09-25
Please, use this
Text from terminal
to make it more readable in the forum.
Maybe a forum newbie could explain how to format terminal text here in a way that is even more understandable to newbies.
, post
a
Here.
or this?
date: 07/20/2015
ID-1: BAT0 charge: 12.1 Wh (49.8%) condition: 24.3/37.3 Wh (65.2%)
volts: 16.7 min: 14.8 model: Lenovo IdeaPad type: Unknown serial: <filter>
status: charging
Speed (MHz): avg: 898 min/max: 800/2700 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 898 2: 898 3: 898 4: 898 bogomips: 19154
vulnerable
address: <filter>
Local Storage: total: 465.76 GiB used: 16.21 GiB (3.5%)
scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 16.21 GiB
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 16.21
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 16.21
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 16.21
System Temperatures: cpu: 55.0 C mobo: N/A gpu: radeon temp: 46.0 C
Processes: 231 Uptime: 25m wakeups: 1 Memory: 11.59 GiB used: 3.01 GiB
(26.0%) Init: systemd v: 251 default: graphical tool: systemctl
inxi: 3.3.21
Garuda (2.6.7-1):
Why you post garuda-inxi again?
Do
garuda-update
in terminal.
Kernel is
Kernel: 5.19.13-zen1-1-zen
Try disabling audio power saving, such as is described here: Advanced Linux Sound Architecture/Troubleshooting - ArchWiki
hi Bluish , i tried to edit /etc/modprobe.d/modprobe.conf but the file doesn't exist ,
cat /etc/modprobe.d/modprobe.conf
cat: /etc/modprobe.d/modprobe.conf: No such file or directory
My knowledge with linux is not that deep
what should i do now?
i updated the system in first of October but the laptop didn't start because there was something wrong , so i used an old snap and restored it , is it safe now to update ?
Commonly, this file does not exist by default and needs to be added by the user.
micro /etc/modprobe.d/modprobe.conf
Add the recommended line to the file (it will be an empty file):
options snd_hda_intel power_save=0 power_save_controller=N
Ctrl+q
to quit out of Micro, make sure you save the file. Then reboot and test it out.
Thank you from the bottom of my heart Bluish , the annoying sound has gone .
i am really appreciated.
regards.
