Android emulator suggestions
android amuleter koi badhiyasa batao yaar
https://aur.archlinux.org/packages/anbox-git/
Try android86 or anbox
bro dono use kiya genymosun bhi trai kiya nox or memu jesa wrk nahi he
If you legit want a decent experience with Android on a computer, I'd dual boot with Android86. Everything just doesn't really feel that great in my experience.
Well, I agree that for best experience, run android specific os.
I personally like bliss os because it is better looking.
Moreover, android86 have android 9 support whereas bliss os have android 10 and 11 in beta testing.
But it is matter of choice, imo.
bro bliss os android 9 tak hi he 10 or 11 to fak he bliss os 12 jisme android 10 he wo loga se aage badh hi nahi raha he 4 bar trai kiiya install bhi nahi horaha or open bhi nai
bro android86 acha he no daud par sirf dekhne ke liye or livewolpepar ke liye game 70 % run nahi ho rahi he install ho jati he
bro android86 android 9 tak he fir bhi bahut kuch sapot nahi karta or nox android 7 pe kam karta he firbhi bahut kuch sapot karta he
Mai toh Android sirf WhatsApp ke liye hi use kar raha hu. Baki sab ke liye Linux hi achcha hai :slight_smile:
bro 5.10.11 aaj aaya kiya ??? isse chengis kiya aayega hum fill karpayene ? :star_struck:
how can i dual boot in garuda ?
I am trying to dual boot the phoenix os with garuda but i am failing at that , Still i was able to follow arch linux based instruction to follow steps and succeded in upto adding entry using 40_custom script and updated grub ,
####SCRIPT######
#Phoenix OS grub settings
menuentry "Phoenix" {
insmod part_gpt
search --file --no-floppy --set=root /Phoenix/kernel
linux /Phoenix/kernel root=/dev/ram0 androidboot.hardware=android_x86 androidboot.setlinux=permissive
initrd /Phoenix/initrd.img
#End of Phoenix Settings
#######END#######
But when rebooting i did get the menu entry in garuda grub , when i loaded it says you need to load kernel first or no device found
Please, open new topic and welcome to Garuda forum. :slight_smile:
