Ive put a checkmark into the setup menu where it asked me if i wanted anbox so i thought it should work out of the box. But when i try to start Anbox this error message comes in the console:
anbox session-manager
[ 2023-01-04 14:34:08] [session_manager.cpp:149@operator()] Failed to start as either binder or ashmem kernel drivers are not loaded
Kernel: 6.1.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=19b4b864-0368-4329-8773-a9306586e158 rw rootflags=subvol=@
resume=UUID=2ea35ee8-0309-4b87-880e-0bd79bc920c9 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> UEFI: American Megatrends v: B.40
date: 11/07/2019
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4324 high: 4325 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4324 2: 4324
3: 4324 4: 4325 5: 4325 6: 4325 7: 4323 8: 4321 9: 4325 10: 4325 11: 4324
12: 4324 bogomips: 91201
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 2b:00.0
chip-ID: 1002:731f class-ID: 0300
s-diag: 1245mm (49.01")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: right model: Asus VP228
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: BenQ GL2706PQ serial: <filter> built: 2016 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
API: OpenGL v: 4.6 Mesa 22.3.2 renderer: AMD Radeon RX 5600 XT (navi10
LLVM 14.0.6 DRM 3.49 6.1.2-zen1-1-zen) direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 3-1:2 pcie: chip-ID: 5678:1234 gen: 4 speed: 16 GT/s class-ID: 0300
lanes: 16 serial: <filter> bus-ID: 2b:00.1 chip-ID: 1002:ab38
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Moman EM1 Microphone type: USB
Sound API: ALSA v: k6.1.2-zen1-1-zen running: yes
vendor: Micro-Star MSI driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 25:00.0
IF: enp37s0 state: down mac: <filter>
Device-2: Realtek RTL8811AU 802.11a/b/g/n/ac WLAN Adapter type: USB
driver: rtl88XXau bus-ID: 1-1:2 chip-ID: 0bda:a811 class-ID: 0000
IF: wlp3s0f0u1 state: up mac: <filter>
Local Storage: total: 3.18 TiB used: 22.55 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA300
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 750 EVO 500GB
ID-1: / raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
used: 22.55 GiB (5.2%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-4: /var/log raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 1.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.43 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 59.6 C mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 58.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1289
Processes: 384 Uptime: 46m wakeups: 0 Memory: 31.3 GiB
used: 6.72 GiB (21.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 2046
libs: 543 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.13-1):
System install date: 2023-01-04
Last full system update: 2023-01-04
