Hi,
I was trying to resolve my problem on my own, but ran out of ideas. Just after installation the fresh garuda system hangs on loading initial ramdisk. When I leave the installation USB drive the startup goes smoothly.
Do you have any idea how USB drive could be linked with the startup (grub)? The grub config points to UUID of my hard disk and there is no indication that the USB drive would be used for anything during the startup. At some point I re-created the grub.cfg using chroot with linux started from the USB drive. Could that generate my issue? The grub-mkconfig made at that point looked like this one:
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-10-26 11:54:03 | @/.snapshots/30/snapshot | post | emacs libotf libxaw m17n-db m17n-lib tree-sitter vim vim-runtime |
Found snapshot: 2023-10-26 11:54:01 | @/.snapshots/29/snapshot | pre | pacman -S vim emacs |
Found snapshot: 2023-10-26 11:50:51 | @/.snapshots/28/snapshot | post | elixir erlang libmspack wxwidgets-common wxwidgets-gtk3 |
Found snapshot: 2023-10-26 11:50:49 | @/.snapshots/27/snapshot | pre | pacman -S erlang elixir |
Found snapshot: 2023-10-26 01:05:36 | @/.snapshots/26/snapshot | post | lib32-acl lib32-gettext lib32-libnl lib32-libpcap wine |
Found snapshot: 2023-10-26 01:05:33 | @/.snapshots/25/snapshot | pre | pacman -S multilib/wine |
Found snapshot: 2023-10-26 00:56:16 | @/.snapshots/24/snapshot | post | gamemode |
Found snapshot: 2023-10-26 00:56:15 | @/.snapshots/23/snapshot | pre | pacman -S extra/gamemode |
Found snapshot: 2023-10-25 22:57:12 | @/.snapshots/22/snapshot | post | mesa-utils |
Found snapshot: 2023-10-25 22:57:11 | @/.snapshots/21/snapshot | pre | pacman -S extra/mesa-utils |
Found 10 snapshot(s)
Unmount /tmp/grub-btrfs.mYSYreDpar .. Success
done
Garuda inxi:
sudo garuda-inxi
Kernel: 6.5.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=064f5cda-0c29-42f7-abdd-20d3903825ef rw rootflags=subvol=@ ibt=off nomodeset
i915.modeset=0 nouveau.modeset=0 rcutree.rcu_idle_gp_delay=1 rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Console: pty pts/1 DM: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP ZBook 15 v: A3009CD10002 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 1909 v: KBC Version 94.50 serial: <filter> UEFI: Hewlett-Packard
v: L70 Ver. 01.07 date: 01/10/2014
ID-1: BAT0 charge: 55.8 Wh (97.0%) condition: 57.5/57.5 Wh (100.0%) volts: 16.6 min: 14.4
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: not charging
Info: model: Intel Core i7-4800MQ socket: LGA1150 (U3E1) note: check bits: 64 type: MT MCP
arch: Haswell gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2095 high: 3700 min/max: 800/3700 base/boost: 2700/2700 scaling:
driver: intel_cpufreq governor: schedutil volts: 0.9 V ext-clock: 100 MHz cores: 1: 800 2: 3700
3: 2961 4: 800 5: 1600 6: 3700 7: 2400 8: 800 bogomips: 43099
Device-1: NVIDIA GK107GLM [Quadro K1100M] vendor: Hewlett-Packard ZBook 15 driver: nvidia
v: 390.157 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx process: TSMC 28nm built: 2012-18
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:0ff6 class-ID: 0300
Device-2: Lite-On HP HD Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-7:7 chip-ID: 04ca:7025 class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.9 compositor: Picom v: git-b700a driver: X:
loaded: nvidia gpu: nvidia tty: 312x60
Monitor-1: Unknown-1 size-res: N/A in console modes: 1920x1080
API: EGL v: 1.5 platforms: gbm: drv: kms_swrast surfaceless: drv: swrast inactive: wayland,x11
API: OpenGL v: 4.5 vendor: mesa v: 23.2.1-arch1.2 note: console (EGL sourced)
renderer: llvmpipe (LLVM 16.0.6 256 bits)
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: discrete-gpu name: Quadro K1100M driver: N/A
device-ID: 10de:0ff6 surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: N/A
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Hewlett-Packard ZBook 15
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: Hewlett-Packard ZBook 15 driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
API: ALSA v: k6.5.8-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.83 status: n/a (root, process) with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack
type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Ethernet I217-LM vendor: Hewlett-Packard ZBook 15 driver: e1000e v: kernel
port: 6040 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 5c:00.0 chip-ID: 8086:088e class-ID: 0280
Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-12:10 chip-ID: 8087:07da class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 454.46 GiB used: 27.2 GiB (6.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 054
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 3.0 size: 7.32 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 446.83 GiB size: 446.83 GiB (100.00%) used: 27.2 GiB (6.1%) fs: btrfs
block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 446.83 GiB size: 446.83 GiB (100.00%) used: 27.2 GiB (6.1%) fs: btrfs
ID-4: /var/log raw-size: 446.83 GiB size: 446.83 GiB (100.00%) used: 27.2 GiB (6.1%) fs: btrfs
ID-5: /var/tmp raw-size: 446.83 GiB size: 446.83 GiB (100.00%) used: 27.2 GiB (6.1%) fs: btrfs
ID-1: swap-1 type: zram size: 23.25 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 243 Uptime: 52m wakeups: 1 Memory: total: 24 GiB available: 23.25 GiB
used: 1.39 GiB (6.0%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1276 libs: 385 tools: octopi,paru
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: pty pts/1 (SSH) inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-25
Last full system update: 2023-10-26
There /dev/sdb (my USB drive) is mentioned here, I’m not sure how that impacts the grub configuration.
Greetings,
pickme467
