Hi,
Using Garuda: garuda-dr460nized-linux-tkg-bmq-210107.iso
I was updating my computer day before yesterday, (I had not done it for a while) and restarted my computer. I was able to login properly with my user, but once logged in, some of the above and below portions of my screen stop responding. The mouse does work in those areas (and KRunner also works), but no window is rendered in the area. There is one thin area in the middle of the screen which works properly. I tried to restart, but the problem persisted.
I thought this might be caused by me not shifting to non-git versions of packages as told in https://forum.garudalinux.org/t/transition-to-fixed-release-packages/5613 (I am new to garuda, so I am not sure
). Switching to fixed release packages did not work either. Also, alacritty shows a lot of warning messages like in https://forum.garudalinux.org/t/when-i-open-console-then-its-shows-some-text/6989. But the solution shown there does not work for me (do not know if that is relevant).
Output of inxi -Fxxxza
System: Kernel: 5.11.17-152-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=db8ae1fb-f80d-42ea-92da-84f2a93df45c rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 resume=UUID=62cf41bd-318b-4740-88f9-9ace3ed0e2b1
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: GOOGLE model: Zako v: 1.0 serial: <filter> UEFI: coreboot v: MrChromebox-4.11.2
date: 03/17/2020
CPU: Info: Dual Core model: Intel Core i7-4600U bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 45 (69)
stepping: 1 microcode: 26 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 16779
Speed: 3060 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 3060 2: 2993 3: 3153 4: 3036
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics vendor: Google driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Monitor-1: HDMI1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Haswell-ULT HD Audio vendor: Google driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Google driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
Sound Server-1: ALSA v: k5.11.17-152-tkg-bmq running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: 2000 bus-ID: 01:00.0
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Hewlett-Packard driver: ath9k v: kernel
port: 2000 bus-ID: 02:00.0 chip-ID: 168c:0034 class-ID: 0280
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-4:6 chip-ID: 0cf3:311e class-ID: e001
Drives: Local Storage: total: 119.24 GiB used: 42.68 GiB (35.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: OSC model: M.2 128GB size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 7A scheme: GPT
Partition: ID-1: / raw-size: 110.15 GiB size: 110.15 GiB (100.00%) used: 42.67 GiB (38.7%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%) fs: vfat dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw-size: 110.15 GiB size: 110.15 GiB (100.00%) used: 42.67 GiB (38.7%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 110.15 GiB size: 110.15 GiB (100.00%) used: 42.67 GiB (38.7%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 110.15 GiB size: 110.15 GiB (100.00%) used: 42.67 GiB (38.7%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
ID-2: swap-2 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 127.5 C mobo: N/A
Info: Processes: 237 Uptime: 22m wakeups: 0 Memory: 7.65 GiB used: 3.63 GiB (47.5%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1723 lib: 360 Shell: fish v: 3.2.1 running-in: alacritty
inxi: 3.3.04
Let me know if more information is needed.
EDIT: This seems to be random. Sometimes it works properly, sometimes I face this problem. I had tried restarting the computer 5-7 times and saw this result.
Thanks
