Fairly new to Garuda and just want to say I love the OS. So far everythingg has been working near perfectly. I do notice that when I add something to latte dock on a dual monitor system and move a icon on one monitor the latte dock on the second monitor goes crazy and all the icons move back and fourth. Its a easy fix though. I just close out latte dock and reload it. i would personally prefer to get rid of latte off the secondary monitor. I'll figure that out another day. The reason I am here though is because I really enjoy Gardua's grub set up. However, I can't seem to get it to show Nobara (Fedora) in the boot menu. If you notice in my posts below it certainly sees it and says it adds it to the menu, but when it boots it doesn't show up in the menu. It's not an emergency I can get in all of my systems. I can switch between refind, and my two grubs in bios so not a a big deal. But I would just prefer to use Garuda strictly because I love the way it works and looks. I did search for a answer in the forums and couldn't find one. So I copied some of the requested postings from other questions and included in my post to help speed things up and hopefully give you everything you need to help me out without having to ask a lot of questions. Thank you in advance for your help and time.
─λ sudo garuda-in
[sudo] password for jj78:
Kernel: 5.19.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: root=UUID=7c0035c0-6c1b-480f-b5b0-020c0884e8da rw
rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=ab7b1e7a-eba8-4439-8cbe-c82aadb79203 loglevel=3
initrd=@\boot\initramfs-linux-zen.img
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Desktop System: Dell product: XPS 8940 v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: Dell model: 0K3CM7 v: A00 serial: <filter> UEFI: Dell v: 2.9.0
date: 07/13/2022
Device-1: hidpp_battery_0 model: Logitech K850 Performance Wireless
Keyboard serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: discharging
Info: model: 11th Gen Intel Core i7-11700 socket: LGA1151 (U3E1)
note: check bits: 64 type: MT MCP arch: Rocket Lake gen: core 11
built: 2021+ process: Intel 14nm family: 6 model-id: 0xA7 (167)
stepping: 1 microcode: 0x53
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1582 high: 2500 min/max: 800/4800:4900
base/boost: 2500/4200 scaling: driver: intel_pstate governor: powersave
volts: 0.8 V ext-clock: 100 MHz cores: 1: 800 2: 800 3: 2500 4: 2500
5: 800 6: 801 7: 801 8: 800 9: 800 10: 2500 11: 2500 12: 2500 13: 2500
14: 800 15: 1420 16: 2500 bogomips: 79872
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 0000:00:02.0 chip-ID: 8086:4c8a class-ID: 0300
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti] vendor: Dell driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-22 bus-ID: 0000:02:00.0 chip-ID: 10de:2486 class-ID: 0300
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915,nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 82 s-size: 1189x331mm (46.81x13.03")
s-diag: 1234mm (48.59")
Monitor-1: DP-5 pos: primary,right res: 1920x1080 hz: 60 dpi: 82
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 75 dpi: 93
OpenGL: renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 0000:00:1f.3 chip-ID: 8086:f1c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 0000:02:00.1 chip-ID: 10de:228b
Sound Server-1: ALSA v: k5.19.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:06f0
Device-2: Realtek vendor: Rivet Networks driver: r8169 v: kernel
port: 3000 bus-ID: 0000:03:00.0 chip-ID: 10ec:2600 class-ID: 0200
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Comet Lake PCH-H RAID driver: intel_nvme_remap v: N/A
port: 5060 bus-ID: 0000:00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
Local Storage: total: 3.24 TiB used: 99.41 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KBG40ZNS512G
NVMe KIOXIA 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 10410106 temp: 53.9 C
SMART: yes health: PASSED on: 116d 21h cycles: 255 read-units: 9,177,199
[4.69 TB] written-units: 7,466,591 [3.82 TB]
model: WD10EZEX-75WN4A1 family: Blue size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 7113 temp: 34 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 116d 1h cycles: 256
read: 189.65 GiB written: 247.57 GiB
ID-3: /dev/sdb maj-min: 8:16 model: SSD size: 953.87 GiB block-size:
physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 8A0 temp: 40 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 43 hrs cycles: 134
read: 5.9 MiB written: 3.8 MiB
ID-4: /dev/sdc maj-min: 8:32 vendor: Silicon Power model: SPCC Solid
State Disk size: 953.87 GiB block-size: physical: 512 B logical: 512 B
sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4A0 temp: 40 C
SMART: yes state: enabled health: PASSED on: 27 hrs cycles: 32
read: 491 KiB written: 1.8 MiB
ID-1: / raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 21.42 GiB
(7.3%) fs: btrfs block-size: 4096 B dev: /dev/sdc1 maj-min: 8:33
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 2 MiB
(0.2%) fs: vfat block-size: 512 B dev: /dev/sdc4 maj-min: 8:36
ID-3: /home raw-size: 627.89 GiB size: 627.89 GiB (100.00%) used: 78 GiB
(12.4%) fs: btrfs block-size: 4096 B dev: /dev/sdc3 maj-min: 8:35
ID-4: /var/log raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 21.42
GiB (7.3%) fs: btrfs block-size: 4096 B dev: /dev/sdc1 maj-min: 8:33
ID-5: /var/tmp raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 21.42
ID-1: swap-1 type: zram size: 31.02 GiB used: 84.2 MiB (0.3%)
ID-2: swap-2 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc2 maj-min: 8:34
System Temperatures: cpu: 50.0 C pch: 49.0 C mobo: 41.0 C gpu: nvidia
temp: 42 C
Fan Speeds (RPM): cpu: 996 fan-1: 811 gpu: nvidia fan: 0%
Processes: 393 Uptime: 1h 0m wakeups: 38 Memory: 31.02 GiB used: 4.68 GiB
(15.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 1626 lib: 387
inxi: 3.3.20
Garuda (2.6.7-1):
System install date: 2022-09-12
Last full system update: 2022-09-14 ↻
Windows dual boot: Yes
Failed units: systemd-networkd-wait-online. Service
efibootmgr -v
efibootmgr -v
BootCurrent: 0004
Timeout: 0 seconds
BootOrder: 0004,0006,0001,0000,0002,0003
Boot0000* Windows Boot Manager HD(1,GPT,83820e4d-d48b-4b6c-bd35-dd670c446ace,0x800,0x4b000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000000000100000010000000040000007fff0400
dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 b0 04 00 00 00 00 00 4d 0e 82 83 8b d4 6c 4b bd 35 dd 67 0c 44 6a ce 02 02 / 04 04 46 00 5c 00 45 00 46 00 49 00 5c 00 4d 00 69 00 63 00 72 00 6f 00 73 00 6f 00 66 00 74 00 5c 00 42 00 6f 00 6f 00 74 00 5c 00 62 00 6f 00 6f 00 74 00 6d 00 67 00 66 00 77 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
data: 57 49 4e 44 4f 57 53 00 01 00 00 00 88 00 00 00 78 00 00 00 42 00 43 00 44 00 4f 00 42 00 4a 00 45 00 43 00 54 00 3d 00 7b 00 39 00 64 00 65 00 61 00 38 00 36 00 32 00 63 00 2d 00 35 00 63 00 64 00 64 00 2d 00 34 00 65 00 37 00 30 00 2d 00 61 00 63 00 63 00 31 00 2d 00 66 00 33 00 32 00 62 00 33 00 34 00 34 00 64 00 3400 37 00 39 00 35 00 7d 00 00 00 00 00 01 00 00 00 10 00 00 00 04 00 00 00 7f ff 04 00
Boot0001* Nobara HD(1,MBR,0x51c82198,0x800,0x200000)/File(\EFI\fedora\shimx64.efi)
dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 00 20 00 00 00 00 00 98 21 c8 51 00 00 00 00 00 00 00 00 00 00 00 00 01 01 / 04 04 34 00 5c 00 45 00 46 00 49 00 5c 00 66 00 65 00 64 00 6f 00 72 00 61 00 5c 00 73 00 68 00 69 00 6d 00 78 00 36 00 34 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
Boot0002* Onboard NIC(IPV4) PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(b04f1303ebf2,0)/IPv4(0.0.0.00.0.0.0,0,0)0000424f
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 1c / 01 01 06 00 00 00 / 03 0b 25 00 b0 4f 13 03 eb f2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 03 0c 1b 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
data: 00 00 42 4f
Boot0003* Onboard NIC(IPV6) PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(b04f1303ebf2,0)/IPv6([::]:<->[::]:,0,0)0000424f
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 1c / 01 01 06 00 00 00 / 03 0b 25 00 b0 4f 13 03 eb f2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 03 0d 3c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
data: 00 00 42 4f
Boot0004* rEFInd Boot Manager HD(4,GPT,4aee34ae-7c26-6740-9592-16d19fb725bc,0x800,0x200000)/File(\EFI\refind\refind_x64.efi)
dp: 04 01 2a 00 04 00 00 00 00 08 00 00 00 00 00 00 00 00 20 00 00 00 00 00 ae 34 ee 4a 26 7c 40 67 95 92 16 d1 9f b7 25 bc 02 02 / 04 04 3a 00 5c 00 45 00 46 00 49 00 5c 00 72 00 65 00 66 00 69 00 6e 00 64 00 5c 00 72 00 65 00 66 00 69 00 6e 00 64 00 5f 00 78 00 36 00 34 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
Boot0006* Garuda HD(4,GPT,4aee34ae-7c26-6740-9592-16d19fb725bc,0x800,0x200000)/File(\EFI\Garuda\grubx64.efi)
dp: 04 01 2a 00 04 00 00 00 00 08 00 00 00 00 00 00 00 00 20 00 00 00 00 00 ae 34 ee 4a 26 7c 40 67 95 92 16 d1 9f b7 25 bc 02 02 / 04 04 34 00 5c 00 45 00 46 00 49 00 5c 00 47 00 61 00 72 00 75 00 64 00 61 00 5c 00 67 00 72 00 75 00 62 00 78 00 36 00 34 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
sudo os-prober
╰─λ sudo os-prober
/dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi
/dev/sdb3:Nobara Linux 36 (KDE Plasma):Nobara:linux:btrfs:UUID=b81ff9f2-215e-428b-bd22-064507cef543:subvol=roo
t
sudo update-grub
â•─jj78@jj78 in ~ as đź§™ took 4s
╰─λ sudo update-grub
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
fgrep: warning: fgrep is obsolescent; using grep -F
Found linux image: /boot/vmlinuz-linux-lts
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-lts.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-lts-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
Found Nobara Linux 36 (KDE Plasma) on /dev/sdb3
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2022-09-14 16:02:28 | @/.snapshots/32/snapshot | post | bluemail |
Found snapshot: 2022-09-14 16:02:26 | @/.snapshots/31/snapshot | pre | /usr/bin/pacman -S --noconfirm chaotic-aur/bluemail |
Found snapshot: 2022-09-14 16:02:07 | @/.snapshots/30/snapshot | post | ufw-extras |
Found snapshot: 2022-09-14 16:02:06 | @/.snapshots/29/snapshot | pre | /usr/bin/pacman -S --noconfirm --asdeps community/ufw-extras |
Found snapshot: 2022-09-14 16:02:04 | @/.snapshots/28/snapshot | post | dropbox |
Found snapshot: 2022-09-14 16:02:03 | @/.snapshots/27/snapshot | pre | /usr/bin/pacman -S --noconfirm chaotic-aur/dropbox |
Found snapshot: 2022-09-14 15:55:15 | @/.snapshots/26/snapshot | post | embree expect kdsoap python-idna whois|
Found snapshot: 2022-09-14 15:55:14 | @/.snapshots/25/snapshot | pre | pacman -Su --config /tmp/tmp.idTNkK1bin |
Found snapshot: 2022-09-14 07:58:12 | @/.snapshots/24/snapshot | post | curl plasma-integration plasma-workspace ttf-iosevka-nerd wayland-utils |
Found snapshot: 2022-09-14 07:58:06 | @/.snapshots/23/snapshot | pre | pacman -Su |
Found 10 snapshot(s)
Unmount /tmp/grub-btrfs.84YYPlRnc9 .. Success
done
/etc/default/grub.conf
# GRUB boot loader configuration
GRUB_DEFAULT="0"
GRUB_TIMEOUT=30
GRUB_DISTRIBUTOR="Garuda"
GRUB_CMDLINE_LINUX_DEFAULT="quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 resume=UUID=ab7b1e7a-eba8-4439-8cbe-c82aadb79203 loglevel=3"
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT=30
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/garuda-dr460nized/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
GRUB_DISABLE_SUBMENU=y
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
GRUB_DISABLE_OS_PROBER=false
