I use GarudaLinux in the Sway - Edition, which I noticed that you can not set the password for the WLAN via the garuda-network-assistant. Of course it works with 'iwctl'.
The second is that garuda-boot-options does not work. The following error message appears:
Authorization required, but no authorization protocol specified
qt.qpa.xcb: could not connect to display :0
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
This is not a problem for me, but could be one for beginners. Although beginners probably don't use Sway.
I dont think its a issue, it is intended to be that way.
I think it is a problem. What use is a programme that shows me the wifi networks, but you can't connect to them? See the screenshot.
Sorry for the external link, I am not allowed to upload pictures yet
What are you doing in garuda boot options please provide context
The context was simply that I wanted to start the program "garuda-boot-options" and it doesn't do that. Not even with root rights.
I can't be so sure on the first issue. The 2nd one wasn't so clear in the original post you didn't mention you got the error on start. The first thing to do is re install garuda boot options
I've tried both garuda-boot-options and garuda-boot-options-git with the same error
fish: Job 1, 'sudo garuda-boot-options' terminated by signal SIGABRT (Abort)
