As dr460nf1r3 says, if rolling back a snapshot doesn’t help. Try to take a bootable USB with garuda on it and chroot into your system and reinstall grub.
Thank you for responding sir would you please give me a walk or a link i can follow to do this live ISO solution cause i tried doing it hy using thr grub console
grub> ls
(hd0) , (hd0,msdos1)
grub> ls (hd0,msdos1)
Partition hd0,msdos1: Filesystem btrfs. UUID (with id ) (partition size)
Then i tried setting up prefixes and set root
grub>insmod linux
file 'usr/lib/grub/i386-pc/linux.mod' not found
wdym? I attached the link to chroot right there in my previous post. To chroot into your device you need a bootable USB with garuda on it. Once you have booted into the live ISO you can either
a. Use the boot repair option in garuda welcome to reinstall grub, or if you have trouble using this GUI utility
b. Follow this link - How to chroot Garuda Linux (also added in my previous post) to manually chroot into your device and reinstall grub.
