Good morning, I installed Garuda about 2 months ago, after many years of Ubuntu and Debian... this pc has a built in 3d card that I have never used and I would like to know what application or driver I need to install to use it! I don't even know what kind of card it is, if it is for watching fim with passive glasses or if it is more powerful! I hope someone can help me! I attach the details of the terminal:
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation Iris Plus Graphics G1 (Ice Lake) (rev 07)
inxi -Fxxxza
Kernel: 6.3.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=46df1d68-cf46-431e-a4a0-b9791adcdb6b rw rootflags=subvol=@
resume=UUID=4aa4fb62-c1cf-44fd-91ea-1f1f5f9ece4b loglevel=3 ibt=off
Desktop: GNOME v: 44.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: Acer product: Aspire A315-57G v: V1.14
Mobo: IL model: Happy_IL v: V1.14 serial: <superuser required>
UEFI: Insyde v: 1.14 date: 09/02/2021
ID-1: BAT1 charge: 9.6 Wh (49.0%) condition: 19.6/41.6 Wh (47.2%)
volts: 11.0 min: 11.2 model: LGC AP19B8K type: Li-ion serial: <filter>
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBA
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1223 high: 1299 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 1292 3: 1200
4: 1200 5: 1200 6: 1200 7: 1299 8: 1200 bogomips: 19046
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
conditional, RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Acer Incorporated ALI
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:1d16
class-ID: 0302
Device-3: Chicony VGA WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 04f2:b5e0
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
display-ID: :1 screens: 1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2017 res: 1920x1080
ratio: 16:9 modes: 1920x1080
missing.
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
API: ALSA v: k6.3.5-zen2-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3
Local Storage: total: 476.94 GiB used: 109.54 GiB (23.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AA
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFK52.3 temp: 29.9 C
used: 109.54 GiB (23.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.54 GiB used: 173.2 MiB (2.2%)
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 292 Uptime: 30m wakeups: 1 Memory: available: 7.54 GiB
used: 4.19 GiB (55.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1316 libs: 403 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
