3 problems when it comes to Garuda gaming
Hello!
I wanted to ask help for some problems I encountered when gaming on Garuda. First of all, I can't make MangoHud work on OpenGL games, I tried searching online, on reddit and anywhere else, but didn't found a solution. I tried adding commands to start options in steam, but it didn't work. Then my second problem is sometimes the audio stops working and then suddenly come back to work normally, this is like hiccups. Last but not least I was wondering if there was a way to make bluetooth controllers automatically turn off after 10m of inactivity since Steam's option doesn't work. Thanks in advance to whoever's gonna help! :slight_smile:
Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e5f9e04c-db20-405d-9081-f080bb5c40c0 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.C0
date: 03/13/2023
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3792 high: 3793 min/max: N/A cores: 1: 3793 2: 3789
3: 3793 4: 3793 5: 3791 6: 3793 7: 3791 8: 3793 9: 3793 10: 3793 11: 3793
12: 3793 13: 3790 14: 3793 15: 3793 16: 3788 bogomips: 121369
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] driver: nvidia
v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 10:00.0 chip-ID: 10de:2488
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none empty: DP-1,DP-2,HDMI-A-1
bus-ID: 30:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 38.0 C
Device-3: WN-258-210721 TT 4K Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.4:9
chip-ID: 0edc:3080 class-ID: 0102 serial: <filter>
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,amdgpu
Screen-1: 0 s-res: 3840x2160 s-dpi: 60 s-size: 1626x914mm (64.02x35.98")
s-diag: 1865mm (73.44")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 61
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.27") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 10:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1 chip-ID: 1002:1637
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6 chip-ID: 1022:15e3
Device-4: Focusrite-Novation Scarlett Solo (3rd Gen.)
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-10:12 chip-ID: 1235:8211 class-ID: 0102 serial: <filter>
Device-5: WN-258-210721 TT 4K Webcam driver: snd-usb-audio,uvcvideo
Device-6: C-Media USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-9:11 chip-ID: 0d8c:0012 class-ID: 0300
API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api with: aoss
speed: 5 GT/s lanes: 1 port: d000 bus-ID: 22:00.0 chip-ID: 10ec:8125
lanes: 1 port: c000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: down mac: <filter>
IF-ID-1: wlp22s0f0u4i2 state: down mac: <filter>
Device-1: Realtek 802.11ac NIC driver: btusb,rtw_8821cu type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 0bda:c820
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 4.68 TiB used: 1.43 TiB (30.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Fanxiang model: S880 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: SN11273 temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler G3
size: 14.9 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
ID-5: /dev/sdd maj-min: 8:48 vendor: Netac model: OnlyDisk
size: 116.21 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1100 scheme: GPT
ID-1: / raw-size: 847.66 GiB size: 847.66 GiB (100.00%)
used: 276.31 GiB (32.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 45.9 MiB (47.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 847.66 GiB size: 847.66 GiB (100.00%)
ID-4: /var/log raw-size: 847.66 GiB size: 847.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 847.66 GiB size: 847.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 27.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.8 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 38 C fan: 56% device: amdgpu
temp: 39.0 C
Processes: 419 Uptime: 2h 3m wakeups: 0 Memory: total: 28 GiB
available: 27.3 GiB used: 9.11 GiB (33.4%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 1974 pm: pacman pkgs: 1936 libs: 564 tools: octopi,pamac,paru,yay
pm: flatpak pkgs: 38 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.29
System install date:     2023-08-09
Last full system update: 2023-08-17 ↻
Failed units:            systemd-sysctl.service
Hi!
I’m not the most knowledgeable in these matters, but:
  • MangoHud should work
https://wiki.archlinux.org/title/MangoHud
Maybe try this resource
  • For the sound issues, try disabling jamesdsp if you have it enabled
  • For the bluetooth thing, maybe read on from here:
https://wiki.archlinux.org/title/Bluetooth_mouse
I’m sure someone will give you some more in depth solutions tho :smiley:
Hi thanks for your answer! So I'll correct myself: MangoHud works, but only for games which works with DirectX and Vulkan, the overlay is correctly displayed. However when I start games such as The Binding of Isaac: Rebirth or Fable Anniversary the overlay doesn't appear to be shown. I tried also setting Steam's start command or env in .profile but it didn't work. My MangoHud is set to "Global enable" and I'd like to make it work globally also for OpenGL games. For the sound issue I haven't got any JamesDSP enabled and it happens only when I'm gaming, there's no problem with other medias.
