Zu langsame Netzwerkverbindung
  Kernel: 6.1.53-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
    root=UUID=9b25f65f-e826-42c0-8494-74e026abb99d rw rootflags=subvol=@ quiet quiet
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm v: 4.18.0 vt: 7
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: B550 Phantom Gaming 4 serial: <superuser required>
    UEFI: American Megatrends LLC. v: P2.40 date: 10/19/2022
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check
    built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113) stepping: 0
    microcode: 0x8701021
    desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2629 high: 4186 min/max: 2200/4208 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2150 2: 2200 3: 2200 4: 2200 5: 2200 6: 2798
    7: 2200 8: 2053 9: 3593 10: 3574 11: 4186 12: 2200 bogomips: 86269
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nvidia v: 535.104.05
    alternate: nouveau,nvidia_drm non-free: 535.xx+ status: current (as of 2023-08) arch: Pascal
    code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 05:00.0 chip-ID: 10de:1c82 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X: loaded: nvidia
    unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
    s-diag: 1055mm (41.55")
  Monitor-1: HDMI-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 94
    size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
  Monitor-2: HDMI-2 pos: right res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.51x11.54")
  API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
    direct-render: Yes
  Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.1.53-1-lts status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8168
    v: 8.051.02-NAPI modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
  IF: enp4s0 state: up speed: 10 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.27 TiB used: 22.71 GiB (1.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK SN770 1TB
    serial: <filter> fw-rev: 731100WD temp: 35.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1B6Q
  ID-3: /dev/sdb maj-min: 8:16 model: 1IMATION RDX-SATA size: 465.76 GiB block-size:
    physical: 512 B logical: 512 B speed: 1.5 Gb/s tech: N/A serial: <filter> fw
-rev: 0036
    scheme: MBR
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 22.71 GiB (2.4%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
    dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 22.71 GiB (2.4%) fs: btrfs
  ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 22.71 GiB (2.4%) fs: btrfs
  ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 22.71 GiB (2.4%) fs: btrfs
  ID-1: swap-1 type: zram size: 15.54 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
  System Temperatures: cpu: 38.2 C mobo: N/A gpu: nvidia temp: 49 C
  Processes: 334 Uptime: 3m wakeups: 0 Memory: total: 16 GiB available: 15.54 GiB
  used: 2.02 GiB (13.0%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
  gcc: 13.2.1 Packages: pm: pacman pkgs: 1452 libs: 458 tools: pamac,paru Client: shell wrapper
  v: 5.1.16-release inxi: 3.3.29
  System install date:     2023-09-05
  Last full system update: 2023-09-16
Hi,
habe das Problem das die Netzwerkkarte nicht richtig funktioniert. Erst hatte ich einen Zen3 Kernel drauf da hat die Ethernet Verbindung nur ab und zu funktioniert. Daher bin ich zurück zum vorherigen Kernel. Jetzt ist die Verbindung zwar besser aber nur 10Mbit anstatt Gigabit. Alle Geräte in meinem Netzwerk laufen im Gigabitbereich. Unter Windows mein Rechner hier auch. Leider nicht unter Garuda. habe zwar schon was hier gelesen über solche Probleme mit anderen Boardherstellern, aber verstehe leider noch nicht wie ich mir selbst helfen kann. Ich hoffe mir kann hier jemand helfen.
Vielen Dank im Voraus!
Jesufi
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e800 bus-ID: 02:00.0
Vielleicht musst du den r8168 blacklisten damit der r 8169 genommen wird?
In meinem alten Rechner habe ich mit der Karte keine Probleme.
Aber Netzwerk gehört nicht zu meiner Kernkompetenz :smiley:
Achja, auch zen, du kannst lts probieren.
Und die Kabel checken, Kinder, Hamster, Hasen, Katzen, junge Hunde in der Wohnung? :smiley:
Danke für die Antwort! Ok wie mache ich das denn? Wenn ich Windows boote habe ich volle Leistung.
Frau, Kinder, Katze und Hund habe ich schon ins Kreuzverhör genommen. Die scheinen es wohl nicht gewesen zu sein :joy:
Als Anmerkung noch die Netzwerkkarte ist auf dem Mainboard integriert falls daswichtig sein sollte.
Bitte immer die Suche Forum/Internet verwenden, wir wollen hier im Forum nicht alles immer wiederholen.
Ich muss immer deepl.com verwenden für englischen Sachen. :smiley:
Windows immer herunterfahren und dann Linux neu starten, Fast- und Secureboot im BIOS deaktivieren.
Beiträge bitte nicht unterschreiben, dein Nick steht ja schon oben :wink:
Danke für den Tip mit dem Übersetzer. Habe im entsprechenden Ordner modprobe.d bereits 8169 auf der Blacklist. Leider noch gleiches Phänomen.
Es ist kein Fast-, Dual- oder Secureboot aktiviert.
Muss das nicht umgekehrt sein?
Bei mir ist der r8169 in Betrieb.
Sorry ja ist richtig. Habe ich mich verschrieben. In der Blacklist steht auch r8168.
Warum auch immer benutzt er jetzt aber immer noch den r8168.
reboot?
Update: Selbst hinbekommen=> 8169(!) wird nun entlich verwendet. Geschwindigkeit ist aber immernoch nicht richtig…
