Hello everyone. I’ve been getting an error during boot ever since I installed, and since I reinstalled and moved /home to a new NVMe. During boot, the 1st line I see is:
[ 3.663622] Initramfs unpacking failed: ZSTD-compressed data is corrupt.
I found a solution to use mknitcpio to regenerate a new image but we don’t have mkinitcpio anymore and when I try to install it it conflicts with garuda-dracut-support. I’m not sure how to proceed. I suspect the problem is more than OS deep because I cant boot the arch installer iso either. It gives me a similar error and doesn’t even boot. Here is my inxi.
╭─user@zbook in ~/Documents/sd/zroot/genevn as 🧙 took 11s
[🔴] × garuda-inxi
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6cf87e5f-470c-4bbe-af32-0537b7707158 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: HP product: HP ZBook 15 G3 v: N/A
Mobo: HP model: 80D5 v: KBC Version 10.75 serial: <superuser required>
part-nu: Y4W53US#ABA uuid: <superuser required> UEFI: HP v: N81 Ver. 01.61
date: 10/03/2023
ID-1: BAT0 charge: 96.6 Wh (100.0%) condition: 96.6/90.0 Wh (107.4%)
volts: 12.4 min: 11.1 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full cycles: 20
Info: model: Intel Core i7-6820HQ bits: 64 type: MT MCP arch: Skylake-S
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 837 high: 900 min/max: 800/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 900 3: 800 4: 800
5: 800 6: 800 7: 900 8: 900 bogomips: 43198
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107GLM [Quadro M2000M] vendor: Hewlett-Packard
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none empty: DP-4,DP-5,DP-6
bus-ID: 01:00.0 chip-ID: 10de:13b0 class-ID: 0300
Device-3: Chicony HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 04f2:b51c
class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: iris
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia wayland: drv: iris x11: drv: iris inactive: gbm,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:191b memory: 61.12 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu
name: Quadro M2000M driver: nvidia v: 550.54.14 device-ID: 10de:13b0
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:5 chip-ID: 8087:0a2b
rfk-block: hardware: no software: no address: <filter> bt-v: 4.2 lmp-v: 8
Local Storage: total: 2.29 TiB used: 282.01 GiB (12.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Fanxiang model: S690Q 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: VF001C30 temp: 31.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Fanxiang model: S101Q 512GB
tech: SSD serial: <filter> fw-rev: 4A0 scheme: GPT
ID-1: / raw-size: 64 GiB size: 64 GiB (100.00%) used: 40.37 GiB (63.1%)
used: 27.1 MiB (2.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.76 TiB size: 1.76 TiB (100.00%)
used: 241.62 GiB (13.4%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 64 GiB size: 64 GiB (100.00%)
used: 40.37 GiB (63.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 64 GiB size: 64 GiB (100.00%)
Kernel: swappiness: 1 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 62.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C pch: 51.5 C mobo: N/A
Memory: total: 64 GiB note: est. available: 62.59 GiB used: 5.24 GiB (8.4%)
Processes: 292 Power: uptime: 1h 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.99 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1996 libs: 557 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 13.2.1 alt: 12 Shell: garuda-inxi
default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-05
Last full system update: 2024-03-12
Failed units: systemd-sysctl.service
Any help would be much appreciated. Thank you.
