Hey together,
Zoom does not work for me anymore, one month already, and now I invested few time into this issue. Firefox doesn’t even trigger a message box anymore for opening the link when I go to a zoom link. The packager is linked to Garuda, so this is why I write here.
When I launch Zoom from the launcher or the Konsole, it will just do nothing and block the Konsole. There is no visible terminal output. Reinstalling did not help. It does not even work with sudo
which, according to the error message, needs to be used with --no-sandbox
. Only when I ran sudo zoom --no-sandbox
, the Zoom application window actually showed up.
The upside is, we have been using BigBlueButton as a replacement since. Access is provided by our university and it’s quite okay, it works certainly better than I remember Jitsi to work.
Well, now I have been reading about why it might be sandboxed and it doesn’t sound nice, like the Chinese Totalitarian Party being able to capture your stream data.
My question is, how is Zoom supposed to be used in Garuda? I couldn’t quickly find anyone bringing this issue up. Being required to use “no sandbox” as an option seems ridiculous, defying its existence. Only one month ago, maybe after an update, it happened that I could’t use Zoom anymore.
Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=11d26dd1-3904-490b-9e30-1b11c6731dc0 rw rootflags=subvol=@
resume=UUID=bbfad61d-c762-4f28-a49c-e041bde44e28 loglevel=3 ibt=off
Type: Detachable System: SHIFT product: SHIFT13mi v: N/A
Mobo: SHIFT model: SHIFT13mi-pcb v: 06 serial: <superuser required>
part-nu: 0752454247011 uuid: <superuser required> UEFI: American Megatrends
LLC. v: 5.19 date: 01/13/2023
ID-1: BAT0 charge: 40.3 Wh (80.8%) condition: 49.9/53.9 Wh (92.5%)
volts: 12.2 min: 11.6 model: Intel SR 1 SR Real Battery type: Unknown
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 961 high: 1332 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 1327 3: 1061
4: 1332 5: 1122 6: 400 7: 892 8: 1155 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Orbbec 3D USB 2.0 Camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2
chip-ID: 2bc5:051e class-ID: 0102 serial: <filter>
Monitor-1: eDP-1 model: BOE Display 0x08dd built: 2019 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 30.36 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 24.0.1-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 953.87 GiB used: 139 GiB (14.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM6A1 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: V1.25D temp: 25.9 C
ID-1: / raw-size: 48.14 GiB size: 48.14 GiB (100.00%) used: 25.9 GiB (53.8%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 588 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 280.27 GiB size: 280.27 GiB (100.00%)
used: 113.1 GiB (40.4%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
ID-4: /var/log raw-size: 48.14 GiB size: 48.14 GiB (100.00%)
used: 25.9 GiB (53.8%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-5: /var/tmp raw-size: 48.14 GiB size: 48.14 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.09 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 3.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p9 maj-min: 259:9
System Temperatures: cpu: 25.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.09 GiB used: 4.83 GiB (15.5%)
Processes: 332 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
Packages: pm: pacman pkgs: 2094 libs: 562 tools: pamac,paru Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
Garuda (2.6.23-1):
System install date: 2023-04-30
Last full system update: 2024-02-26
I just saw, there is a new Zoom update and just installed it. Then reboot.
Now it works again. It starts with a crash reporter window, but when clicking it away it shows up normally again.
