Hello,
For some reason whenever firedrgon is opened, a zombie process is created with it, tried killing parent process and restarting but nothing works.
$ ps aux | grep -E "<defunct>"
asa 14398 0.0 0.0 0 0 ? Z 10:23 0:00 [firedragon] <defunct>
$ zps -l
PID PPID STATE NAME COMMAND
16513 16463 Z firedragon
$ zps -r
[Terminated]
PID: 16513
PPID: 16463
State: Z
1 defunct process(es) cleaned up in 0.69s
Reopening firedragon brings zombie process to a new pid
$ zps -l
17076 17024 Z firedragon
Here is my system details.
$ garuda-inxi
Kernel: 6.1.2-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=fff1a130-5283-4cb4-9626-0e18df0efc8c rw [email protected]
resume=UUID=36b59a06-7ef5-4227-ab86-ec3c5a46bd4e loglevel=3
sysrq_always_enabled=1 systemd.unified_cgroup_hierarchy=1 ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81NB v: Lenovo IdeaPad S340-14API
serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad S340-14API
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN serial: <filter>
UEFI: LENOVO v: AMCN31WW(V1.14) date: 06/08/2022
ID-1: BAT1 charge: 29.5 Wh (55.7%) condition: 53.0/52.5 Wh (101.0%)
volts: 11.6 min: 11.3 model: 0x4C 0x47 0x43 0x00 0x32 0x30 0x 0x4C 0x31
0x38 0x33 0x50 0x5250 type: Li-ion serial: <filter> status: not charging
cycles: 543
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx socket: FP5
bits: 64 type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3
note: check built: 2019 process: GF 12nm family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1487 high: 2100 min/max: 1400/2100 boost: enabled
base/boost: 2100/3700 scaling: driver: acpi-cpufreq governor: ondemand
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 2100 6: 1400 7: 1400 8: 1400 bogomips: 33550
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 77.0 C
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-4:5 chip-ID: 174f:2426 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x05ec built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.2 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 14.0.6 DRM 3.49 6.1.2-arch1-1) direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.6
Sound API: ALSA v: k6.1.2-arch1-1 running: yes
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Lenovo ThinkPad E595 driver: rtw_8822be v: N/A modules: rtw88_8822be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
chip-ID: 10ec:b822 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-1.1:5 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp4s0f3u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-2:2 chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 1.14 TiB used: 68.77 GiB (5.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo O.E.M.
model: RPFTJ256PDD2MWX size: 238.47 GiB block-size: physical: 512 B
rev: 11.9 temp: 52.9 C scheme: GPT
SMART: yes health: PASSED on: 41d 23h cycles: 3,262
read-units: 61,174,535 [31.3 TB] written-units: 39,288,907 [20.1 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
family: Mobile HDD size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: LFM1 temp: 41 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 211d 10h cycles: 3051
Old-Age: g-sense error rate: 150 Pre-Fail: attribute: Spin_Retry_Count
ID-1: / raw-size: 85.25 GiB size: 85.25 GiB (100.00%)
used: 68.77 GiB (80.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
used: 596 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-3: /home raw-size: 85.25 GiB size: 85.25 GiB (100.00%)
maj-min: 259:7
ID-4: /var/log raw-size: 85.25 GiB size: 85.25 GiB (100.00%)
maj-min: 259:7
ID-5: /var/tmp raw-size: 85.25 GiB size: 85.25 GiB (100.00%)
maj-min: 259:7
ID-1: swap-1 type: zram size: 5.73 GiB used: 1007.5 MiB (17.2%)
ID-2: swap-2 type: partition size: 5.86 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 77.9 C mobo: N/A gpu: amdgpu temp: 77.0 C
Processes: 303 Uptime: 10m wakeups: 4 Memory: 5.73 GiB
used: 3.26 GiB (56.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2299
pm: pacman pkgs: 2293 libs: 499 tools: octopi,pamac,paru pm: flatpak pkgs: 6
inxi: 3.3.24
Garuda (2.6.13-1):
System install date: 2022-08-01
Last full system update: 2023-01-04
Windows dual boot: Yes
Failed units: samba.service
