I am making an attempt to install linux on my Asus Zephyrus 15 Duo (2021) laptop. I should note that I have tried Pop_OS before Garuda, but overall, Garuda has given the best out-of-box experience hands down.
Anyways, in both installs, I have hit a common problem (and they both have pipewire) - Sound works and comes out just fine. Volume sliders change in every tool (system audio, alsamixer, pavucontrol and etc) and even through the keyboard shortcuts. HOWEVER, the actual volume coming out of the speakers remains exactly the same with no change.
Does anyone have any idea what could be happening and how to fix?
╰─λ garuda-inxi
Kernel: 6.10.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4ea12ae0-6cc4-4c2b-9869-18a4fe09be4c rw rootflags=subvol=@
quiet rd.luks.uuid=1b5d2ec8-adaf-48bd-a8d4-ae7d7513381f loglevel=3
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: ASUSTeK product: ROG Zephyrus Duo 15 SE GX551QR_GX551QR
Mobo: ASUSTeK model: GX551QR v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: GX551QR.405
date: 05/13/2021
ID-1: BAT0 charge: 69.2 Wh (100.0%) condition: 69.2/90.0 Wh (76.9%)
volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging
Device-1: hid-0018:04F3:2A5A.0001-battery model: ELAN9009:00 04F3:2A5A
serial: N/A charge: N/A status: N/A
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 772 high: 2734 min/max: 400/4890 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 2734
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 2081 16: 2349 bogomips: 105409
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-1 empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:249d
link-max: gen: 4 speed: 16 GT/s ports: active: none off: eDP-1 empty: DP-2
bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 52.0 C
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: DP-1 res: 3440x1440 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.2-arch1.1
renoir LLVM 18.1.8 DRM 3.57 6.10.8-zen1-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.2-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3070 Laptop GPU driver: nvidia
v: 560.35.03 device-ID: 10de:249d surfaces: xcb,xlib,wayland device: 2
v: 24.2.2-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Device-4: Plantronics Poly BT700 driver: plantronics,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.2.1.1:8
chip-ID: 047f:02e6 class-ID: 0300 serial: <filter>
Device-5: Silicon Motion - Taiwan (formerly Feiya ) SMI USB Display
lanes: 1 mode: 2.0 bus-ID: 3-1.4:7 chip-ID: 090c:0768 class-ID: 0300
API: ALSA v: k6.10.8-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.3.1:5
IF: enp7s0f4u1u3u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 8087:0032
Local Storage: total: 1.86 TiB used: 10.38 GiB (0.5%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: GXA7301Q temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 39.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: SMI (STMicroelectronics)
model: INSTANTVIEW size: 14.65 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: N/A serial: <filter> fw-rev: 1100
used: 10.38 GiB (1.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-1b5d2ec8-adaf-48bd-a8d4-ae7d7513381f
used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 30.76 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 60.8 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): cpu: 2000
Memory: total: 32 GiB note: est. available: 30.76 GiB used: 5.65 GiB (18.4%)
Processes: 369 Power: uptime: 30m states: freeze,mem,disk suspend: s2idle
image: 12.25 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1363 libs: 387 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date: 2024-09-07
Last full system update: 2024-09-07
[🧱] × aplay --list-devices --list-pcms
null
Discard all samples (playback) or generate zero samples (capture)
pipewire
PipeWire Sound Server
default
Default ALSA Output (currently PipeWire Media Server)
hdmi:CARD=NVidia,DEV=0
HDA NVidia, LG ULTRAWIDE
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
sysdefault:CARD=Generic
HD-Audio Generic, ALC285 Analog
Default Audio Device
front:CARD=Generic,DEV=0
Front output / input
surround21:CARD=Generic,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
sysdefault:CARD=Display
SMI USB Display, USB Audio
front:CARD=Display,DEV=0
surround21:CARD=Display,DEV=0
surround40:CARD=Display,DEV=0
surround41:CARD=Display,DEV=0
surround50:CARD=Display,DEV=0
surround51:CARD=Display,DEV=0
surround71:CARD=Display,DEV=0
iec958:CARD=Display,DEV=0
IEC958 (S/PDIF) Digital Audio Output
sysdefault:CARD=BT700
Poly BT700, USB Audio
front:CARD=BT700,DEV=0
surround21:CARD=BT700,DEV=0
surround40:CARD=BT700,DEV=0
surround41:CARD=BT700,DEV=0
surround50:CARD=BT700,DEV=0
surround51:CARD=BT700,DEV=0
surround71:CARD=BT700,DEV=0
iec958:CARD=BT700,DEV=0
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [LG ULTRAWIDE]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC285 Analog [ALC285 Analog]
Subdevices: 1/1
card 2: Display [SMI USB Display], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 3: BT700 [Poly BT700], device 0: USB Audio [USB Audio]
Subdevices: 1/1
╰─λ lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
Subsystem: ASUSTeK Computer Inc. Device 1652
Kernel driver in use: pcieport
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation GA104M [GeForce RTX 3070 Mobile / Max-Q] (rev a1)
Subsystem: ASUSTeK Computer Inc. Device 11bc
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
02:00.0 SD Host controller: Genesys Logic, Inc GL9755 SD Host Controller
Subsystem: ASUSTeK Computer Inc. Device 202f
Kernel driver in use: sdhci-pci
Kernel modules: sdhci_pci
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: ASUSTeK Computer Inc. Device 208f
Kernel driver in use: r8169
Kernel modules: r8169
04:00.0 Network controller: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
05:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
Subsystem: Samsung Electronics Co Ltd SSD 980 PRO
Kernel driver in use: nvme
Kernel modules: nvme
06:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller 980 (DRAM-less)
Subsystem: Samsung Electronics Co Ltd Device a801
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] (rev c4)
Kernel driver in use: amdgpu
Kernel modules: amdgpu
07:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Kernel driver in use: ccp
Kernel modules: ccp
07:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
Subsystem: ASUSTeK Computer Inc. Device 201f
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
07:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
07:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63
07:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
