Zen kernels and my chipsets
Background info:
OS: Garuda Dr460nized KDE x86_64 / Linux 6.17.6-zen1-1-zen
Desktop Env: KDE Plasma 6.5.1 / KWin (Wayland)
Rig: hp elitebook 655 g11 / Ryzen 5 7535U (6:12 cores @ 4.63Ghz) / Radeon 680M / 64Gb DDR5 / 4Tb M2
Idk how I missed this little ditty for nearly all of 2025, but I just now learned that Garuda’s Zen kernels are supposed to fit excellently with AMD chips. I’ve just always preferred AMD over Intel, probably because I had an Intel 386/33-66 way back in the day that gave me so many headaches. Anyways, that above is the list of what I’m running currently. With the Zen /AMD bit, are there any conf or setting changes I need/should make to take full advantage of that combo or are there special packages from the chaotic-AUR repo that’d help? Thanks in advance.
All should work out of the box using the default kernel (zen).
I have 9800X3D, and both zen as well zen5 work more or less the same. But as a daily driver I use zen5 reason is that this kernel get sooner the updates than the zen kernel.
Do not worry about kernels. Just have installed 2 or 3 (default + LTS + mainline). If something goes wrong you can during boot in grub switch the kernel and see if that helps with potential issues.
Ok. Kernel wise though where I’m using zen1, it just feels like I ought to step up the # a bit no?
Back in the past, various kernels provided various optimality. But nowadays as we speak about gaming. The difference in performance between kernels is negligible.
Heya! I just want to clarify that the zen part on linux-zen does not refer to the zen architecture of Ryzen processors.
In this case, the kernel you are looking for is linux-znver3 alongside linux-znver3-headers.
I switched to the Linux-zen3 (and grabbed the headers too) without problems. FEI (for everyone’s info) I did notice an appreciable performance boost so yeah, definitely worth It. Thanks everyone
