usb-us122l.ko.zst.iS6Nxz : Invalid argument (22) rsync: [receiver] failed to set permissions on /usr/lib/modules/6.5.9-zen2-1-zen/kernel/sound/usb/usx2y/.
snd-usb-usx2y.ko.zst.y6BGzW : Invalid argument (22) rsync: [receiver] failed to set permissions on /usr/lib/modules/6.5.9-zen2-1-zen/kernel/sound/virtio/.
virtio_snd.ko.zst.4rw71n : Invalid argument (22) rsync: [receiver] failed to set permissions on /usr/lib/modules/6.5.9-zen2-1-zen/kernel/sound/x86/.
snd-hdmi-lpe-audio.ko.zst.qsjNbn : Invalid argument (22) rsync: [receiver] failed to set permissions on /usr/lib/modules/6.5.9-zen2-1-zen/kernel/sound/xen/.
snd_xen_front.ko.zst.xCpaj4 : Invalid argument (22) rsync: [receiver] failed to set permissions on /usr/lib/modules/6.5.9-zen2-1-zen/kernel/virt/lib/.
irqbypass.ko.zst.xfTRx6 : Invalid argument (22) rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1338) [sender=3.3.0]
these are the errors that occured during the recent update if someone can tell me what to do?
Can you provide your
As per the forum template
parameters: BOOT_IMAGE=/@/.snapshots/17/snapshot/boot/vmlinuz-linux-zen
root=UUID=286935d0-910e-4cf2-aa80-38e37cb3dcc5 quiet loglevel=3 ibt=off
rootflags=defaults,noatime,compress=zstd,subvol=@/.snapshots/17/snapshot
Type: Laptop System: ASUSTeK product: ROG Strix G513QY_G513QY v: 1.0
Mobo: ASUSTeK model: G513QY v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513QY.331 date: 02/24/2023
ID-1: BAT0 charge: 33.4 Wh (48.1%) condition: 69.5/90.0 Wh (77.2%)
power: 17.6 W volts: 14.4 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 596 high: 1542 min/max: 400/4890 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 1542
4: 400 5: 400 6: 400 7: 1397 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 1397 16: 400 bogomips: 105402
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: none empty: DP-1 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0380
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 08:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 38.0 C
s-diag: 777mm (30.58")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a07 built: 2021
res: 2560x1440 hz: 165 dpi: 189 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast surfaceless: drv: radeonsi
x11: drv: radeonsi inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:1638 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: AMD Radeon RX 6800M (RADV NAVI22) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:73df surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: AMD Navi 21/23 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:ab28 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks [] driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 13d3:3563
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 1.84 TiB used: 26.24 GiB (1.4%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: FXM7201Q temp: 37.9 C scheme: GPT
ID-1: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 26.5 MiB (10.4%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-2: /home raw-size: 149.49 GiB size: 149.49 GiB (100.00%)
used: 26.22 GiB (17.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /var/log raw-size: 149.49 GiB size: 149.49 GiB (100.00%)
ID-4: /var/tmp raw-size: 149.49 GiB size: 149.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A
GPU: device: amdgpu temp: 45.0 C mem: 38.0 C fan: 0 watts: 6.00
device: amdgpu temp: 39.0 C
Processes: 390 Uptime: 24m wakeups: 7 Memory: total: 16 GiB note: est.
available: 15.03 GiB used: 3.51 GiB (23.3%) Init: systemd v: 254
pm: pacman pkgs: 1187 libs: 351 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2024-04-17
Last full system update: 2024-04-17
Failed units: snapper-cleanup.service systemd-remount-fs.service
here is the garuda-inxi
SGS
18 April 2024 11:11
4
Please post full log, include your update command.
Format as text like the garuda-inxi.
I tried to fix your log from first post, maybe I failed
nepti
18 April 2024 12:55
5
hellraiser:
You are in a snapshot. Why?
Boot your garuda normally (w/o snapshot) and try again.
system
Closed
2 May 2024 12:55
6
