I’m experiencing a repeatable audio issue on Garuda Linux. Every time I open a YouTube video in Firefox Nightly, the YouTube player volume immediately drops from 100% to 71%. It also happens whenever the video refreshes itself, for example when changing quality. Firefox Nightly shows the internal volume as 1.0, but YouTube keeps forcing it back to 71%.
I searched the web, checked the Garuda Wiki and FAQs, and looked for similar cases on the forum but didn’t find anything relevant. I also tried restarting Firefox, disabling extensions, clearing site settings, and testing with hardware acceleration on/off. The issue persists.
╰─λ garuda-inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_CTYPE = (unset),
LC_NUMERIC = "it_CH.UTF-8",
LC_COLLATE = (unset),
LC_TIME = "it_IT.UTF-8",
LC_MESSAGES = (unset),
LC_MONETARY = "it_CH.UTF-8",
LC_ADDRESS = "it_CH.UTF-8",
LC_IDENTIFICATION = "it_IT.UTF-8",
LC_MEASUREMENT = "it_IT.UTF-8",
LC_PAPER = "it_IT.UTF-8",
LC_TELEPHONE = "it_CH.UTF-8",
LC_NAME = "it_CH.UTF-8",
LANG = "it_IT.UTF-8"
perl: warning: Falling back to a fallback locale ("it_IT.UTF-8").
Kernel: 6.17.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=eda78aa1-5090-4e06-beb8-4f5848aff3f6 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Convertible System: LENOVO product: 21LXS0PC00 v: ThinkPad X13 2-in-1
Gen 5 serial: <superuser required> Chassis: type: 31
Mobo: LENOVO model: 21LXS0PC00 v: SDK0T76530 WIN
serial: <superuser required> part-nu: LENOVO_MT_21LX_BU_Think_FM_ThinkPad
X13 2-in-1 Gen 5 uuid: <superuser required> UEFI: LENOVO
v: N45ET26W (1.16 ) date: 08/13/2025
ID-1: BAT0 charge: 35.2 Wh (100%) condition: 35.2/54.7 Wh (64.4%)
volts: 17.22 min: 15.48 model: BYD 5B11M90051 type: Li-poly serial: <filter>
charging: status: full control: start: 0% end: 100% cycles: 163
Info: model: Intel Core Ultra 5 125U bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x25
Topology: cpus: 1x dies: 1 clusters: 5 cores: 12 threads: 14 mt: 2 tpc: 2
st: 10 smt: enabled cache: L1: 1.2 MiB desc: d-10x32 KiB, 2x48 KiB; i-12x64
KiB L2: 10 MiB desc: 5x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1248 min/max: 400/4300:3600:2100 scaling:
driver: intel_pstate governor: powersave cores: 1: 1248 2: 1248 3: 1248
4: 1248 5: 1248 6: 1248 7: 1248 8: 1248 9: 1248 10: 1248 11: 1248 12: 1248
13: 1248 14: 1248 bogomips: 75264
Device-1: Intel Meteor Lake-P [Intel Graphics] vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+) built: 2023+
ports: active: DP-1,eDP-1 empty: DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:7d45 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:8 chip-ID: 04f2:b806
alternate: fbdev,intel,vesa dri: iris gpu: i915 d-rect: 3840x1200
display-ID: 0
Monitor-1: DP-1 pos: primary,left model: AOC 2475W serial: <filter>
built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
Monitor-2: eDP-1 pos: right model: BOE Display 0x0964 built: 2020 res:
mode: 1920x1200 hz: 60 scale: 125% (1.25) to: 1536x960 dpi: 171 gamma: 1.2
size: 286x179mm (11.26x7.05") diag: 337mm (13.3") ratio: 16:10
modes: 1920x1200
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (MTL)
device-ID: 8086:7d45 memory: 14.7 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 10 device: 0 type: integrated-gpu
name: Intel Graphics (MTL) driver: mesa intel v: 25.2.7-arch1.1
device-ID: 8086:7d45 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.5 256 bits) driver: mesa llvmpipe v: 25.2.7-arch1.1 (LLVM
21.1.5) device-ID: 10005:0000 surfaces: N/A
Device-1: Intel Meteor Lake-P HD Audio vendor: Lenovo
driver: sof-audio-pci-intel-mtl
alternate: snd_sof_pci_intel_mtl,snd_hda_intel bus-ID: 00:1f.3
chip-ID: 8086:7e28 class-ID: 0403
Device-2: Razer USA Barracuda X 2.4
lanes: 1 mode: 1.1 bus-ID: 3-3.2:5 chip-ID: 1532:0552 class-ID: 0301
API: ALSA v: k6.17.8-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.3:3
IF: enp0s13f0u1u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:10 chip-ID: 8087:0033
Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.4 lmp-v: 13
Local Storage: total: 476.94 GiB used: 99.93 GiB (21.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDQNQD-512G-1201 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73117101 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
used: 99.9 GiB (56.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 30.9 MiB (12.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
ID-4: /var/log raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
ID-5: /var/tmp raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.06 GiB used: 14.6 MiB (0.1%)
System Temperatures: cpu: 65.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 15.06 GiB used: 6.79 GiB (45.1%)
Processes: 347 Power: uptime: 19m states: freeze,mem,disk suspend: s2idle
image: 6.01 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 258 default: graphical tool: systemctl
Packages: 2029 pm: dpkg pkgs: 0 pm: pacman pkgs: 1978 libs: 510
tools: octopi,paru,yay pm: rpm pkgs: 32 pm: flatpak pkgs: 19 Compilers:
clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.2.1
Garuda (2.11.1-1):
System install date: 2024-08-26
Garuda release: 240428
Last full system update: 2025-11-24
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 1.34 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
- Deprecated/Outdated/Removed packages should be removed: steam-native-runtime (fix available)
