Your default display manager was changed from
Just went to boot into Garuda and was met with a tty1 prompt. I rebooted and after a couple of tries got a Snapshot from 03-08-23 loaded and working. Launched Timeshift once on the desktop and selected that Snapshot, rebooted and all looks good except of course a massive amount of updates. I noticed the below right at the end of garuda-update and wanted to know if there is anything I should do before doing a restart? I also posted my entire update output to a pastebin if anyone wants to take a look to see if there is anything else besides the below that should be addressed before I do a restart. Thanks
Your default display manager was changed from "sddm-plymouth.service" to "sddm.service" automatically, becaus
e the former no longer exists.
╭─[email protected] in ~
╰─λ garuda-inxi
Kernel: 6.2.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e157f20e-fcfe-4274-8fbf-1c40c3d79f83 rw [email protected]
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4204
date: 01/28/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3602 high: 3686 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3598 2: 3686
3: 3599 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3541 10: 3600 11: 3600
12: 3600 bogomips: 86397
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com.
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.0
chip-ID: 10de:2187 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 23.1.1
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.38x11.14")
s-diag: 727mm (28.63")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97
size: 673x284mm (26.5x11.18") diag: 730mm (28.76") modes: N/A
API: OpenGL v: N/A renderer: N/A direct-render: N/A
Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1
chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.2.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.67 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
driver: btusb v: 0.8 bus-ID: 1-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 26.38 TiB used: 12.97 TiB (49.2%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234100WD temp: 39.9 C scheme: GPT
model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: Expansion HDD size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 1801 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
model: Expansion HDD size: 10.91 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 0003 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate
model: ST8000AS0002-1NA17Z size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5980 serial: <filter> scheme: GPT
ID-1: / raw-size: 92.93 GiB size: 92.93 GiB (100.00%)
used: 43.16 GiB (46.4%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 10.7 MiB (3.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 92.93 GiB size: 92.93 GiB (100.00%)
ID-4: /var/log raw-size: 92.93 GiB size: 92.93 GiB (100.00%)
ID-5: /var/tmp raw-size: 92.93 GiB size: 92.93 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.39 GiB used: 8.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 57.0 C mobo: 46.0 C gpu: nvidia temp: 40 C
Fan Speeds (RPM): cpu: 1534 case-1: 0 case-2: 0 case-3: 0 gpu: nvidia
fan: 0%
Power: 12v: 10.08 5v: N/A 3.3v: N/A vbat: 3.18
Processes: 469 Uptime: 24m wakeups: 6 Memory: 23.39 GiB
used: 7.14 GiB (30.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: 2209 pm: pacman pkgs: 2190
libs: 577 tools: octopi,pamac,paru,pikaur pm: flatpak pkgs: 12 pm: snap
pkgs: 7 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.26
System install date:     2023-03-12
Last full system update: 2023-04-07 ↻
garuda-update
You should be good to go without any further intervention. You kind of dodged a bullet there because folks who took the update before the hotfix was put in were rebooting to a TTY. There were a bunch of posts in the forum about it.
In your case, good timing! :wink:
So I dropped to a tty cause I probably didn't have the hotfix in then, hence the new SDDM service enabled. Wish I had known that cause I'm assuming all I needed to do was start the new SDDM service which I'm assuming the hotfix should of enabled?
Hmm, I was under the impression it would be taken care of. :thinking:
Go ahead and log in on the TTY, then:
sudo systemctl enable --now sddm.service
Edit
I am realizing I just kind of misread your original post, sorry about the confusion.
Originally when you booted to a TTY, enabling the SDDM service would have been your fix.
Since you rolled back and took down a more recent update with the hotfix, you should be good to go without needing to do anything else.
Yes, I believe this is correct.
Thanks worked like a charm.
