Yoshimi does not launch
When I installed Yoshimi synthetiser it first launched correctly but for some time it doesn’t launch at all. Here is the return when I launch it on the terminal.
󰛓 ❯ yoshimi
yoshimi 2.3.5.3 is starting...
Start-up Synth-Instance(0)...
-----Connect-attempt----(jack_audio/alsa_midi)----
finding manual
-----Connect-SUCCESS-------------------
Using jack_audio for audio and alsa_midi for midi
manual found
Found 4468 instruments in 112 banks
No match for root ID 0
Missing recent history file
Set jack session callback failed
Alsa midi priority is 39
Build Number 2413
Clientname: yoshimi
Audio: jack -> 'default'
Midi: alsa -> 'default'
Oscilsize: 512
Samplerate: 48000
Period size: 256
Yay! We're up and running :-)
yoshimi> Failed to load plugin 'libdecor-gtk.so': failed to init
Main Engine initialised
fish: Job 1, 'yoshimi' terminated by signal SIGSEGV (Erreur de frontière d’adresse)
Do you have an idea how to fix that ?
It’s probably an upstream issue in that package when used with wayland (which should be your case, but you didn’t post your garuda-inxi as required in the topic template).
See e g.
There are a couple of interesting links about that issue and a possible workaround. A fix seems to be ongoing (in the -git package), but if I read correctly not working well yet.
Or try an Xorg session.
Ok, sorry, I didn’t need that much assistance on the forum, so I wasn’t used to post here. Here is my garuda-inxi :
❯ garuda-inxi
Kernel: 6.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=5e01f648-b7c5-490a-8ecc-6030048541f3 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
Type: Laptop System: MEDION product: Crawler E30e v: N/A
Mobo: MEDION model: NPxxRNA v: 1.0 serial: <superuser required>
part-nu: ML-210008 40090164 uuid: <superuser required> Firmware: UEFI
vendor: INSYDE v: 1.07.03RME1_00015 date: 10/05/2023
ID-1: BAT0 charge: 38.1 Wh (90.4%) condition: 42.1/52.5 Wh (80.1%)
volts: 16.92 min: 15.4 model: Notebook BAT type: Li-ion serial: <filter>
charging: status: charging cycles: N/A
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
microcode: 0x43A
Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 threads: 12 mt: 4 tpc: 2
st: 4 smt: enabled cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32
KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 600 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 600 2: 600 3: 600 4: 600 5: 600 6: 600 7: 600
8: 600 9: 600 10: 600 11: 600 12: 600 bogomips: 59904
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: CLEVO/KAPOK
built: 2020-21 ports: active: eDP-1 empty: DP-2,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:46a3 class-ID: 0300
Device-2: NVIDIA GA107 [GeForce RTX 2050] vendor: CLEVO/KAPOK
driver: nvidia v: 590.48.01 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:25ad class-ID: 0300
Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:2 chip-ID: 04f2:b729
compositor: kwin_wayland driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0b07 built: 2021 res:
modes: 1920x1080
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 30.3 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.335 layers: 8 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 25.3.4-arch1.1
device-ID: 8086:46a3 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2050 driver: nvidia v: 590.48.01
device-ID: 10de:25ad surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.4-arch1.1 (LLVM
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA107 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.18.6-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 476.94 GiB used: 25.17 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Foresee model: XP2000F512G
lanes: 4 tech: SSD serial: <filter> fw-rev: V1223J0T temp: 27.9 C
ID-1: / raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
used: 24.93 GiB (42.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 242.4 MiB (48.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
ID-4: /var/log raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.03 GiB used: 4.91 GiB (15.8%)
Processes: 369 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1613 libs: 351 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.3.3 running-in: konsole
inxi: 3.3.40
Garuda (2.12.3-2):
System install date:     2026-01-12
Last full system update: 2026-01-25
Relevant software:       snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard
25/26 checks run in 0.77 seconds ⌛
Powered by garuda-health 🦅
Indeed, I am on Wayland, the only possibility I have on the connection page. How can I switch to Xorg ?
You can select it in the login screen.
I’m on Mokka, and there’s a small wheel on the bottom-right.
Change Plasma (Wayland) with x11.
If you’re on Dr460nized, it should be very similar.
IIRC, it is on the lower left side, but I use very old installations.
:smiley:
I don’t have a choice on my login screen. When I click on the wheel, there is only Plasma (Wayland)
It means you should probably install the plasma-x11-session package
Thank you :folded_hands:, that’s what I was looking for ! Yoshimi is launching !
