Hello, today after upgrade and reboot my wifi was gone. I restore last snapshot and I'm wonder wchich package stop and don't upgrade:
Packages (30) botan-3.1.0-1 chaotic-mirrorlist-20230710-2 fakeroot-1.32-1 fwupd-1.9.3-1 game-devices-udev-0.22-0.2 gpgme-1.21.0-1 groff-1.23.0-2 grub-2:2.12rc1-1
imagemagick-7.1.1.12-2 lib32-systemd-253.6-1 libva-mesa-driver-23.1.3-2 mesa-23.1.3-2 mesa-vdpau-23.1.3-2 oath-toolkit-2.6.9-1 python-platformdirs-3.8.1-1
rtw88-dkms-git-r299.919900e-1 standardnotes-bin-3.165.11-1 suitesparse-7.1.0-2 systemd-253.6-2 systemd-libs-253.6-2 systemd-sysvcompat-253.6-2
vulkan-intel-23.1.3-2 vulkan-mesa-layers-23.1.3-2 vulkan-radeon-23.1.3-2 vulkan-swrast-23.1.3-2 wine-staging-8.12-1 xorg-server-21.1.8-2
xorg-server-common-21.1.8-2 xterm-384-1 zoom-5.15.3-1
Total Download Size: 159.92 MiB
Kernel: 6.1.38-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 rw rootflags=subvol=@
resume=UUID=8f7c97f0-2758-4001-95b0-57f15fb14228 loglevel=3 ibt=off
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: HUAWEI product: KLVL-WXX9 v: M1300
Mobo: HUAWEI model: KLVL-WXX9-PCB v: M1300 serial: <superuser required>
UEFI: HUAWEI v: 1.06 date: 09/14/2020
ID-1: BAT0 charge: 28.5 Wh (60.5%) condition: 47.1/54.9 Wh (85.7%)
volts: 7.7 min: 7.6 model: SUNWODA HB4593R1ECW-22S0 type: Li-ion
serial: <filter> status: discharging cycles: 341
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600104
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1399 high: 1400 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1397 2: 1400
3: 1400 4: 1400 5: 1400 6: 1400 7: 1397 8: 1397 9: 1400 10: 1400 11: 1400
12: 1400 bogomips: 71890
Device-1: AMD Renoir vendor: Huaqin driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 34.0 C
Device-2: IMC Networks HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:5451
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0893 built: 2019 res: 2160x1440
dpi: 185 gamma: 1.2 size: 296x197mm (11.65x7.76") diag: 356mm (14")
ratio: 3:2 modes: 2160x1440
API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
Device-1: AMD Renoir Radeon High Definition Audio vendor: Huaqin
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huaqin driver: N/A
snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16
Device-3: AMD Family 17h/19h HD Audio vendor: Huaqin driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
API: ALSA v: k6.1.38-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
vendor: & Tele RSH driver: rtw_8822ce v: kernel modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 1358:c123
address: <filter>
Local Storage: total: 476.94 GiB used: 139.56 GiB (29.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1027 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21117000 temp: 37.9 C scheme: GPT
used: 139.56 GiB (29.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 7.14 GiB used: 478.5 MiB (6.5%)
System Temperatures: cpu: 35.6 C mobo: N/A gpu: amdgpu temp: 35.0 C
Processes: 332 Uptime: 22m wakeups: 1 Memory: available: 7.14 GiB
used: 3.2 GiB (44.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1662
pm: pacman pkgs: 1647 libs: 416 tools: gnome-software,pamac,paru pm: flatpak
pkgs: 15 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.27
System install date: 2022-04-09
Last full system update: 2023-07-10
Failed units: mnt-Seagate.mount mnt-Toshiba.mount
Regards.
