Hey there,
I've just been trying to update my system, but pacman seems to sync all filesystems indefinitely.
There are no dmesg errors indicating issues, but in the console I can see a lot of anannicy infos:
Apr 29 23:54:15 lolcat ananicy-cpp[580]: [2022-04-29 23:54:15.272] [info] mkdir(777343)
Apr 29 23:54:15 lolcat ananicy-cpp[580]: [2022-04-29 23:54:15.539] [info] pacman(777366)
Apr 29 23:54:15 lolcat ananicy-cpp[580]: [2022-04-29 23:54:15.680] [info] pacman(777367)
Apr 29 23:54:15 lolcat ananicy-cpp[580]: [2022-04-29 23:54:15.940] [info] rm(777369)
Apr 29 23:54:16 lolcat ananicy-cpp[580]: [2022-04-29 23:54:16.192] [info] wc(777373)
Apr 29 23:54:16 lolcat ananicy-cpp[580]: [2022-04-29 23:54:16.198] [info] mkdir(777375)
Apr 29 23:54:16 lolcat ananicy-cpp[580]: [2022-04-29 23:54:16.208] [info] pacman(777392)
Apr 29 23:54:16 lolcat ananicy-cpp[580]: [2022-04-29 23:54:16.874] [info] rm(777401)
Apr 29 23:54:21 lolcat ananicy-cpp[580]: [2022-04-29 23:54:21.578] [info] wc(777406)
Apr 29 23:54:21 lolcat ananicy-cpp[580]: [2022-04-29 23:54:21.594] [info] wc(777416)
This has been scrolling through journalctl for about 20 minutes now, and this is definitely not supposed to be happening. Is it a bad idea to kill pacman? I really want to shut off my pc for the night and thus I don't have a lot time.
While writing this I just got crash info in journalctl:
Apr 29 23:55:44 lolcat kernel: INFO: task sync:775829 blocked for more than 122 seconds.
Apr 29 23:55:44 lolcat kernel: Tainted: G W 5.17.5-zen1-1-zen #1
Apr 29 23:55:44 lolcat kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Apr 29 23:55:44 lolcat kernel: task:sync state:D stack: 0 pid:775829 ppid: 1 flags:0x00004006
Apr 29 23:55:44 lolcat kernel: Call Trace:
Apr 29 23:55:44 lolcat kernel: <TASK>
Apr 29 23:55:44 lolcat kernel: ? __x64_sys_tee+0xd0/0xd0
Apr 29 23:55:44 lolcat kernel: __schedule+0xaed/0x1360
Apr 29 23:55:44 lolcat kernel: schedule+0x4b/0xc0
Apr 29 23:55:44 lolcat kernel: sync_inodes_sb+0x304/0x350
Apr 29 23:55:44 lolcat kernel: ? finish_wait+0x80/0x80
Apr 29 23:55:44 lolcat kernel: iterate_supers+0x87/0xf0
Apr 29 23:55:44 lolcat kernel: __do_sys_sync+0x40/0xa0
Apr 29 23:55:44 lolcat kernel: do_syscall_64+0x5c/0x80
Apr 29 23:55:44 lolcat kernel: ? exc_page_fault+0x72/0x170
Apr 29 23:55:44 lolcat kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
Apr 29 23:55:44 lolcat kernel: RIP: 0033:0x7f61dbef129b
Apr 29 23:55:44 lolcat kernel: RSP: 002b:00007ffe49bdb728 EFLAGS: 00000246 ORIG_RAX: 00000000000000a2
Apr 29 23:55:44 lolcat kernel: RAX: ffffffffffffffda RBX: 00007ffe49bdb908 RCX: 00007f61dbef129b
Apr 29 23:55:44 lolcat kernel: RDX: 00007f61dbff2c01 RSI: 00007ffe49bdb908 RDI: 00007f61dbfafdf8
Apr 29 23:55:44 lolcat kernel: RBP: 0000000000000001 R08: 0000000000000001 R09: 0000000000000000
Apr 29 23:55:44 lolcat kernel: R10: 0000559d8797b3b0 R11: 0000000000000246 R12: 0000559d860c3bc0
Apr 29 23:55:44 lolcat kernel: R13: 0000559d860c119e R14: 00007f61dbfea24c R15: 0000559d860c1034
Apr 29 23:55:44 lolcat kernel: </TASK>
How do I stop this process?
Thanks!
Inxi:
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=6e6211b4-cfb4-44c0-8970-5e4a826e0c5e rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1
iommu=soft
Desktop: Unity info: waybar wm: wayfire v: 0.8.0-9458f589 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F50a
date: 11/27/2019
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2968 high: 4158 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2782 2: 2385
3: 3752 4: 3511 5: 4158 6: 2386 7: 2388 8: 3385 9: 2936 10: 3115 11: 2413
12: 2409 bogomips: 86224
Device-1: AMD Baffin [Radeon RX 550 640SP / 560/560X] vendor: ASUSTeK
driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 08:00.0 chip-ID: 1002:67ff
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:3 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: wayfire v: 0.8.0-9458f589 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu d-rect: 3600x1200
display-ID: 1
Monitor-1: DVI-D-1 pos: right res: 1920x1200 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: primary,left res: 1680x1050 size: N/A modes: N/A
OpenGL: renderer: AMD Radeon RX 560 Series (polaris11 LLVM 13.0.1 DRM
3.44 5.17.5-zen1-1-zen)
v: 4.6 Mesa 22.0.2 direct render: Yes
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
lanes: 8 bus-ID: 08:00.1 chip-ID: 1002:aae0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: C-Media USB Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:4 chip-ID: 0d8c:9700
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-3:4 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Local Storage: total: 2.96 TiB used: 1.13 TiB (38.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A82 scheme: GPT
ID-1: / raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
used: 124.77 GiB (64.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 576 KiB (0.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 736.18 GiB size: 736.18 GiB (100.00%)
used: 171.18 GiB (23.3%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 4 MiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1457
Processes: 364 Uptime: 1h 21m wakeups: 0 Memory: 31.3 GiB
used: 4.35 GiB (13.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 2038 apt: 0 pacman: 2020 lib: 495
flatpak: 18 Shell: Zsh v: 5.8.1 running-in: alacritty inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2021-12-28
Last full system update: 2022-04-29 ↻
