Hey guys. Yesterday i was making copies of my files and i was downloading them to my hard drive. Then because there was a major storm we lost power. Today i woke up and i have 3 drives, but i cannot open one of them. It says mount: wrong fs type, bad option, bad superblock. Now i don’t wan’t to format this disk, because i have very important work files, old family pictures etc. But i tried to open that format option to see what would happen and it won’t let me do that either. What can i do to fix this. Also i should mention my drives are not that old, less than a year and i did try to open up my computer and un/plug everything in and out. Root and basic partition are detected but local disk cannot be mounted. I assume this is because everything shut down due to power outage and now some faulty files are messing with my computer. What can we do here to salvage this bad boy ?
Kernel: 6.9.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
root=UUID=b58c058b-2bff-4086-96d2-a19d53deca95 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0 wm: kwin_x11 vt: 2
Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 1.10 date: 08/22/2018
Info: model: Intel Core i7-9700KF bits: 64 type: MCP arch: Coffee Lake gen: core 9 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xC (12)
microcode: 0xF6
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB
L2: 2 MiB desc: 8x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4600 high: 4601 min/max: 800/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 4600 2: 4600 3: 4601 4: 4601 5: 4600 6: 4600 7: 4600 8: 4600
bogomips: 57600
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI driver: nvidia v: 555.58.02
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-06; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: none off: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f02 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1 compositor: kwin_x11 driver: X:
loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 2560x1440 s-dpi: 92 s-size: 707x393mm (27.83x15.47") s-diag: 809mm (31.85")
Monitor-1: DP-1 mapped: DP-0 note: disabled model: AOC Q32G2WG3 serial: <filter> built: 2023
res: 2560x1440 hz: 60 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 2070
driver: nvidia v: 555.58.02 device-ID: 10de:1f02 surfaces: xcb,xlib device: 1 type: cpu
name: llvmpipe (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM 18.1.8)
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.9.9-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 10.96 TiB used: 1.91 TiB (17.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston mode
l: SNV2S2000G size: 1.82 TiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: SBM02103 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SKC6002048G size: 1.86 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0113
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000NT001-3LZ101 size: 7.28 TiB
fw-rev: EN01 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.21 TiB (66.5%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.21 TiB (66.5%) fs: btrfs
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.21 TiB (66.5%) fs: btrfs
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.21 TiB (66.5%) fs: btrfs
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 48.0 C pch: 46.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 17%
Memory: total: 32 GiB available: 31.28 GiB used: 4.15 GiB (13.3%)
Processes: 301 Power: uptime: 8m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.47 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256
Packages: pm: pacman pkgs: 2081 libs: 557 tools: octopi,paru pm: flatpak pkgs: 0 Compilers:
clang: 18.1.8 gcc: 14.1.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.35
System install date: 2024-04-25
Last full system update: 2024-07-14
