Hello,
Running into below question while trying to update.
Please advise on best way to proceed.
Trying to ask before proceeding so as not be break things...
Another related thing is that for awhile now I'm only able to update via garuda-update
The GUI based "Updates - Discover" doesn't seem to reflect the latest updates as before.
Appreciate the helpful answers on here in advance as always! =)
╰─λ garuda-update
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 1867.4 KiB 5.07 MiB/s 00:00 [------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..
garuda 74.8 KiB 169 KiB/s 00:00 [------------------------------------] 100%
core 156.4 KiB 319 KiB/s 00:00 [------------------------------------] 100%
extra 1720.6 KiB 2.72 MiB/s 00:01 [------------------------------------] 100%
community 6.7 MiB 8.33 MiB/s 00:01 [------------------------------------] 100%
multilib 170.8 KiB 351 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 1867.4 KiB 4.92 MiB/s 00:00 [------------------------------------] 100%
spawn pacman -Su
warning: anbox-git: local (1:r1358.84f0268-9.1) is newer than chaotic-aur (1:r1358.84f0268-7)
resolving dependencies...
:: wireplumber and pipewire-media-session are in conflict. Remove pipewire-media-session? [y/N]
Requested info below:
Kernel: 5.18.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=6d358332-1121-46d2-a2c5-bd235a269b18 rw [email protected]
resume=UUID=c06ef7ff-534a-46d8-a0e0-a3052b377e5f loglevel=3
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: LENOVO product: 20X7005AUS v: ThinkPad L15 Gen 2a
Mobo: LENOVO model: 20X7005AUS serial: <superuser required> UEFI: LENOVO
v: R1KET36W (1.21 ) date: 11/25/2021
ID-1: BAT0 charge: 32.5 Wh (73.5%) condition: 44.2/45.7 Wh (96.6%)
volts: 11.6 min: 11.1 model: SMP LNV-5B10W13896 type: Li-poly
serial: <filter> status: discharging cycles: 34
Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1470 high: 2270 min/max: 1600/4505 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1519 2: 1397
3: 1397 4: 1397 5: 1433 6: 1475 7: 1397 8: 1397 9: 1397 10: 1395 11: 1442
12: 2270 13: 1417 14: 1397 15: 1397 16: 1403 bogomips: 60690
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel arch: GCN 5.1
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:1638
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-2:2
chip-ID: 5986:212b class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x2e8d built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.7-zen1-1-zen)
v: 4.6 Mesa 22.1.2 direct render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir
bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.18.7-zen1-1-zen running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8852 class-ID: 0280
bus-ID: 5-4:2 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 476.94 GiB used: 132.05 GiB (27.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X081N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41730C20
temp: 41.9 C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
used: 52.04 GiB (53.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 580 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 358.77 GiB size: 358.77 GiB (100.00%)
used: 80.01 GiB (22.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4
ID-4: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
maj-min: 259:3
ID-5: /var/tmp raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
maj-min: 259:3
ID-1: swap-1 type: zram size: 14.46 GiB used: 2.5 MiB (0.0%)
ID-2: swap-2 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): cpu: 65535 fan-1: 2681 fan-2:
Processes: 382 Uptime: 18m wakeups: 2 Memory: 14.46 GiB
used: 5.47 GiB (37.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 2015
lib: 559 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-04-06
Last full system update: 2022-06-30
Failed units: anbox-container-manager.service systemd-networkd-wait-online.service
