Y Headphone Splitter not working properly
I have a Y splitter for my laptop. When I connect it to the headphone jack, audio doesn’t come out from the built-in speakers even when selecting them as the audio output, and the external microphone I connect to it doesn’t get recognized (confirmed it using pavucontrol). It works properly on windows (I’m dual booting), and in my previous laptop the microphone worked correctly in both Garuda and WIndows (can’t confirm for its built-in speakers, I had it connected to a HDMI TV because my screen got fried). Pavucontrol shows that the speakers outputs audio but is not coming from it. I’m using pipewire.
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
I always forget to post it, sorry.
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=54013b2e-f667-4f78-984b-142f7489c202 rw rootflags=subvol=@
quiet splash acpi_backlight=native ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Laptop System: Acer product: Nitro AN515-58 v: V2.03
Mobo: ADL model: Jimny_ADH v: V2.03 serial: <superuser required>
UEFI: Insyde v: 2.03 date: 02/24/2023
ID-1: BAT1 charge: 56.0 Wh (100.0%) condition: 56.0/57.5 Wh (97.5%)
volts: 17.5 min: 15.4 model: LGC AP21D8M type: Li-ion serial: <filter>
status: full
Info: model: 12th Gen Intel Core i5-12500H bits: 64 type: MST AMCP
microcode: 0x430
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 844 high: 1205 min/max: 400/4500:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 874 2: 1006 3: 1186
4: 400 5: 970 6: 400 7: 982 8: 400 9: 1205 10: 986 11: 933 12: 1035
13: 400 14: 946 15: 1048 16: 746 bogomips: 99532
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.2
process: Intel 10nm built: 2021-22+ ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
vendor: Acer Incorporated ALI driver: N/A alternate: nouveau
non-free: 545.xx+ status: current (as of 2023-10) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ bus-ID: 0000:01:00.0
chip-ID: 10de:28a1 class-ID: 0300
Device-3: Quanta ACER HD User Facing driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0408:4035
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Monitor-1: eDP-1 model: LG Display 0x0742 built: 2021 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 14.97 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 8 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 23.3.2-arch1.2
device-ID: 8086:46a6 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:51f0
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2b:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp43s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 91.34 GiB (6.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA512TFH
lanes: 4 tech: SSD serial: <filter> fw-rev: P7MA000 temp: 38.9 C
model: WD10JPVX-60JC3T1 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
used: 91.33 GiB (9.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 381 Uptime: 1h 20m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.33 GiB used: 6.66 GiB (43.4%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 6/7/8/9
clang: 16.0.6 Packages: pm: pacman pkgs: 2011 libs: 436
tools: octopi,pamac,paru Shell: fish v: 3.7.0 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2023-12-17
Last full system update: 2024-01-11 ↻
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
:smiley:
This is why the garuda-inxi is requested. The ‘swoosh’ indicates a reboot is needed since your last update. We need an updated, rebooted machine to help you the most. :smiley:
I rebooted 2 times already and the ‘swoosh’ is still there, send help
serial:
ID-1: BAT1 charge: 49.8 Wh (88.9%) condition: 56.0/57.5 Wh (97.5%)
volts: 16.2 min: 15.4 model: LGC AP21D8M type: Li-ion serial:
microcode: 0x430
Speed (MHz): avg: 644 high: 1223 min/max: 400/4500:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 1122 3: 400 4: 400
5: 1200 6: 400 7: 951 8: 721 9: 1093 10: 1223 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 99532
class-ID: fe01 serial:
IF: wlp0s20f3 state: up mac:
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.2
Local Storage: total: 1.38 TiB used: 92.58 GiB (6.6%)
lanes: 4 tech: SSD serial: fw-rev: P7MA000 temp: 33.9 C
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial:
used: 92.57 GiB (9.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
Src: /sys System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 357 Uptime: 2m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.33 GiB used: 2.52 GiB (16.5%) Init: systemd v: 255
inxi: 3.3.31
Garuda (2.6.22-1):
Last full system update: 2024-01-12 ↻
Your headphone jack cuts out the internal speaker on every laptop that I have ever used. That’s by design, headphones are a different impedance / Ohms than speakers. It’s can’t put out both. now you could hook up external powered speakers and headphones by using the y adapter with HP and speakers plugged into it, but not recommended. I think the laptop jack has sensing in it or built in circuit that detects whether it;'s low or high impedance. Desktops usually have line out, and sometimes headphone and or line on the case.
