Hi,
When logging in via sddm (or lightdm) into a Plasma (Wayland) session, X doesn't work correctly. When trying to start xeyes from the console I get these Errors:
Invalid MIT-MAGIC-COOKIE-1 keyError: cannot open display ''
when I look into htop, XWayland is there.
Interestingly, when I go to another tty, log in there, and start a new plasma-wayland session like this:
dbus-run-session startplasma-wayland
it works perfectly fine (although I have to unlock kwallet manually)
reinstalling sddm, plymouth or plasma-wayland-session doesn't fix it. installing git versions of these programs also doesn't.
garuda-inxi: (I ran this in a session I started manually from tty3 as described above)
╭─jonathan@JoLi in ~ via v3.10.6 took 2m57s
╰─λ garuda-inxi
Kernel: 5.19.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=ed7d29e6-cb8d-43b9-8031-6acbb474bc2d rw rootflags=subvol=@
amdgpu.ppfeaturemask=0xffffffff acpi_mask_gpe=0x09
wm: kwin_wayland vt: 3 dm: LightDM v: 1.32.0 Distro: Garuda Linux
Type: Desktop Mobo: Gigabyte model: Z690 GAMING X DDR4 v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F6
date: 12/17/2021
Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x22
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 4306 high: 4800 min/max: 800/4800:3600 scaling:
driver: intel_pstate governor: performance cores: 1: 4800 2: 3700 3: 4800
4: 3700 5: 4800 6: 4800 7: 4800 8: 3700 9: 4708 10: 4800 11: 4800
12: 4800 13: 3601 14: 3700 15: 3700 16: 3700 bogomips: 117964
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
ports: active: none empty: DP-4,HDMI-A-2,HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0380
Device-2: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_wayland driver: X: loaded: amdgpu gpu: i915,amdgpu
d-rect: 5760x1080 display-ID: 0
Monitor-1: DP-1 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: center res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 14.0.6 DRM
3.47 5.19.1-zen1-1-zen) v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 1-6:3 v: kernel
alternate: snd_sof_pci_intel_tgl chip-ID: 0dba:3000 bus-ID: 00:1f.3
class-ID: 0102 chip-ID: 8086:7ad0 class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Digidesign Mbox 2 type: USB driver: snd-usb-audio
Sound Server-1: ALSA v: k5.19.1-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
Local Storage: total: 7.06 TiB used: 2.59 TiB (36.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A7C0
model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: MZ7LN256HMJP-000H1
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1H3Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 QVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 191.11 GiB size: 191.11 GiB (100.00%) used: 179.51 GiB
(93.9%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 576 KiB
(0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 848.99
GiB (91.1%) fs: btrfs dev: /dev/sdd1 maj-min: 8:49
ID-4: /var/log raw-size: 191.11 GiB size: 191.11 GiB (100.00%) used: 179.51
GiB (93.9%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
ID-5: /var/tmp raw-size: 191.11 GiB size: 191.11 GiB (100.00%) used: 179.51
ID-1: swap-1 type: zram size: 31.06 GiB used: 3.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 46.87 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35
System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
mem: 48.0 C
Processes: 492 Uptime: 54m wakeups: 0 Memory: 31.06 GiB used: 7.36 GiB
(23.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 alt: 10 clang: 14.0.6 Packages: 2459 pacman: 2454
lib: 572 flatpak: 5 Shell: fish v: 3.5.1 running-in: konsole inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2021-07-26
Last full system update: 2022-08-22 ↻
Snapshots: Timeshift
Failed units: fancontrol.service systemd-networkd-wait-online.service
