I have 2 moniors a primary 2560x1440 with no scaling plugged on DP and a 3840x2160 with 150% scaling on HDMI, the issue is that xwayland app detect both screens as 3840x2160, that makes games and the like detect the wrong resolution and borderless window does not work well, with the window becoming tiny in the desktop if set to 2560x1440. the plasma config is set to “x11 apps scale by themselves”. XWayland was also setting the primary display incorectly and alwayas making games open in the secondary display, i fixed it with a script that runs upon login that sets the DP as primary with xrandr, but i couldnt do the same for the resolution, trying to change it with xrandr or arandr gives an error, changing the second monitor scaling to 100% fixes the resolution on xrandr but it then everything is tiny. Is there a fix? Is it a kde or xwayland issue?
i have same problem…it dont scaling…i try to set 150 and nothing happens…also no hdr option is availible anymore
it would be nice if you add your garuda-inxi to your post
are you on wayland or x11? cause x11 has no hdr
when i switch to wayland i get black screen every 10 seconds and i cant see any settings in nvidia and its laggy like i would have 20 fps -.- 3 days ago at least only the nvidia settings were gone now wits unuseable
Kernel: 6.9.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=66db3818-da99-4708-9d70-d0baacc38fa3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop System: Gigabyte product: X670E AORUS MASTER v: -CF
Mobo: Gigabyte model: X670E AORUS MASTER v: x.x
Megatrends LLC. v: F32a date: 07/05/2024
Info: model: AMD Ryzen 9 7900X3D bits: 64 type: MCP arch: Zen 4 gen: 5
Topology: cpus: 1x cores: 12 smt: <unsupported> cache: L1: 768 KiB
desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB L3: 128 MiB
desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 2275 high: 4797 min/max: 545/5660 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 545 2: 545 3: 545
4: 545 5: 545 6: 545 7: 545 8: 4791 9: 4796 10: 4791 11: 4797 12: 4310
bogomips: 105597
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2684 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
Screen-1: 0 s-res: 3840x2160 s-dpi: 144 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-3 mapped: DP-4 note: disabled model: Gigabyte AORUS FO32U2
serial: <filter> built: 2024 res: 3840x2160 dpi: 141 gamma: 1.2
size: 690x390mm (27.17x15.35") diag: 793mm (31.2") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 555.58.02
device-ID: 10de:2684 surfaces: xcb,xlib
Device-1: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
Device-2: Logitech Yeti X driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 9-1.2:3
chip-ID: 046d:0aaf class-ID: 0300 serial: <filter>
Device-3: Creative Sound BlasterX G6
lanes: 1 mode: 2.0 bus-ID: 9-1.4:4 chip-ID: 041e:3256 class-ID: 0300
API: ALSA v: k6.9.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0d:00.0 chip-ID: 8086:15f3
IF: enp13s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0e:00.0
IF: wlp14s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0032
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 10.94 TiB used: 172.35 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRD2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 30.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Kingston model: SFYRDK4000G
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Kingston model: SFYRD2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 29.9 C
ID-4: /dev/nvme3n1 maj-min: 259:2 vendor: Kingston model: SFYRDK4000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 27.9 C
ID-5: /dev/sda maj-min: 8:0 model: N/A size: 29.3 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 3.00 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 172.35 GiB (9.3%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
used: 172.35 GiB (9.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
ID-1: swap-1 type: zram size: 30.96 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.2 C mobo: N/A gpu: nvidia temp: 38 C
Memory: total: 32 GiB note: est. available: 30.96 GiB used: 3.1 GiB (10.0%)
Processes: 369 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.34 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1815 libs: 532 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-07-17
Last full system update: 2024-07-17
Failed units:`Preformatted text`
i also cant save the nvidia settings
i did google…and this error seems to exist for years a phython gtk or something may can fix it…i have no clue how and what to do…im new linux user (X11)
Start nvidia-settings in terminal as root user.
sudo nvidia-settings
Yeah there are no setting in the wayland side of the nvidia app thats on nvidia and wayland.
but yea sudo nvidia-settings is what to run in x11
Sorry, forgot the inxi
Kernel: 6.9.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=8ae5615f-c6d8-4e31-89de-ac9490bb8ee9 rw rootflags=subvol=@
resume=UUID=357e86cf-c5fb-42d3-9c8d-9dd891f79fd6 loglevel=3 amd_iommu=on
iommu=pt ibt=off
wm: kwin_wayland tools: avail: swaylock vt: 1 dm: SDDM Distro: Garuda
Type: Desktop System: Micro-Star product: MS-7D73 v: 1.0
Mobo: Micro-Star model: MPG B650I EDGE WIFI (MS-7D73) v: 1.0
Megatrends LLC. v: 1.20 date: 03/24/2023
Device-1: hidpp_battery_0 model: Logitech G502 X LIGHTSPEED serial: <filter>
charge: 78% rechargeable: yes status: discharging
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1317 high: 5350 min/max: 400/5573 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5350 2: 400 3: 400
4: 400 5: 400 6: 5250 7: 400 8: 400 9: 400 10: 400 11: 5276 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 144010
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire PULSE driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,HDMI-A-2 empty: DP-2,HDMI-A-1,Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael vendor: Micro-Star MSI driver: vfio-pci v: N/A
alternate: amdgpu arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 13:00.0
chip-ID: 1002:164e class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2023 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-2: HDMI-A-2 model: Samsung U32J59x serial: <filter> built: 2018
res: 3840x2160 dpi: 140 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 3840x2160 min: 720x400
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.3-arch1.1
navi31 LLVM 18.1.8 DRM 3.57 6.9.8-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 15 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.3-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.3-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-2: AMD Rembrandt Radeon High Definition Audio
speed: 16 GT/s lanes: 16 bus-ID: 13:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 13:00.6 chip-ID: 1022:15e3
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:5
chip-ID: 0db0:36e7 class-ID: 0300
Device-5: SteelSeries ApS Arctis Nova Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 1038:12e0 class-ID: 0300
Device-6: Kingston HyperX QuadCast
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 0951:16df class-ID: 0300
API: ALSA v: k6.9.8-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:6 chip-ID: 0e8d:0616
Local Storage: total: 3.64 TiB used: 1.38 TiB (38.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Kingston model: SNV2S2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 37.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SNV2S2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 44.9 C
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.38 TiB (78.8%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 25.9 MiB (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 1.38 TiB (78.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-1: swap-1 type: zram size: 61.96 GiB used: 17.5 MiB (0.0%)
ID-2: swap-2 type: partition size: 68.16 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
System Temperatures: cpu: 54.9 C mobo: 40.0 C gpu: amdgpu temp: 46.0 C
mem: 56.0 C
Memory: total: 64 GiB note: est. available: 61.96 GiB used: 9.29 GiB (15.0%)
Processes: 412 Power: uptime: 7h 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.76 GiB services: org_kde_powerdevil,
Packages: 2525 pm: pacman pkgs: 2489 libs: 595 tools: paru pm: flatpak
pkgs: 36 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: alacritty inxi: 3.3.35
System install date: 2023-08-15
Last full system update: 2024-07-18 ↻
I’m not on nvidia
thats the error i get when trying to use arandr, sometimes xrandr gives me the same error and sometims it does nothing
