XScreensaver settings not opening
Hello not sure if this is the right place but in trying to install XScreensaver I have the problem with not being able to access the settings menu it try I see it pop up in the dock jumping up and down and then it goes away and doesn’t load was wonder if any would know how to fix this. I will also add that the xscreensaver itself does work meaning it will start after 10 minutes but I can’t get into settings. I’ve looked everywhere and all I get is info from 1 or more years ago and this problem just started.
Terminal output of garuda-inxi, as described, please. :slight_smile:
https://wiki.archlinux.org/title/XScreenSaver#Configuration
