I will just start off with inxi before I do anything…
╭─fenris@fenris in ~ took 25ms
╰─λ sudo garuda-inxi
[sudo] password for fenris:
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=cd6e149b-2970-476f-b742-e3dc1120bedc rw rootflags=subvol=@
quiet rd.luks.uuid=264cadad-c8c3-46fe-b132-32f30ff8b69c
rd.luks.uuid=0dd705d1-74f7-4ae7-8f55-96ae57f524b8
resume=/dev/mapper/luks-0dd705d1-74f7-4ae7-8f55-96ae57f524b8 loglevel=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
Type: Desktop Mobo: AZW model: MINI S v: 10 serial: N/A part-nu: 01
uuid: 03000200-0400-0500-0006-000700080009 UEFI: American Megatrends LLC.
v: ADLNV104 date: 02/06/2023
Info: model: Intel N100 socket: U3E1 bits: 64 type: MCP arch: Alder Lake
level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x15
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 700 min/max: 700/3400 base/boost: 2871/3400 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 6451
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
alternate: xe arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: HDMI-A-1 empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:46d1
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:8
chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer G247HYL serial: <filter>
built: 2016 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu
name: Intel Graphics (ADL-N) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel
chip-ID: 8086:54c8 class-ID: 0403
Device-2: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 1-4.3:6 chip-ID: 0d8c:0102 class-ID: 0300
Device-3: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
Device-1: Intel CNVi: Wi-Fi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.1:4
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u4u1 state: down mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
Local Storage: total: 2.73 TiB used: 1.07 TiB (39.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 55.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
used: 27.1 GiB (3.0%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
maj-min: 254:1 mapped: luks-264cadad-c8c3-46fe-b132-32f30ff8b69c
used: 728 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-4: /var/log raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.94 GiB used: 0 KiB (0.0%)
mapped: luks-0dd705d1-74f7-4ae7-8f55-96ae57f524b8
ID-2: swap-2 type: zram size: 15.4 GiB used: 2.57 GiB (16.7%)
System Temperatures: cpu: 59.0 C mobo: N/A
Memory: total: 16 GiB available: 15.4 GiB used: 7.98 GiB (51.8%)
igpu: 60 MiB
Processes: 357 Power: uptime: 1d 17h 50m states: freeze,mem,disk
reboot, suspend, test_resume image: 6.14 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 255
Packages: pm: pacman pkgs: 1759 libs: 469 tools: pamac,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
System install date: 2024-04-11
Last full system update: 2024-04-22 ↻
Failed units: vmware-workstation-server.service vmware.service
╭─fenris@fenris in ~ as 🧙 took 6s
╰─λ
First of all, I installed XRDP it looked like it was working till I connected. Got the login screen but it wasn’t accepting my root username/password. It had a wierd screen on it with a windows blue background telling me it couldn’t accept the username and password.
So I went here to follow these instructions: How to enable remote desktop
Also by doing xfce4-session I get the following and do not know if this is adding to the problem, nor how to fix
╭─fenris@fenris in /mnt/veracrypt1/Videos as 🧙 took 446ms
╰─λ xfce4-session
(xfce4-session:1270493): xfce4-session-WARNING **: 15:41:44.596: Another session manager is already running
╭─fenris@fenris in /mnt/veracrypt1/Videos as 🧙 took 93ms
So I login again from my windows pc, and I get this screen https://user-images.githubusercontent.com/3178490/106655305-144a2980-6591-11eb-9d8f-6344dc2b3c35.png
So I tried to follow this "Unable to contact settings server" when lauching XFCE remote desktop session on CentOS8 · Issue #872 · OSC/ondemand · GitHub which is what I see on the screen
I also looked at this entry [SOLVED] Unable to Contact Settings Server / Applications & Desktop Environments / Arch Linux Forums but it doesn’t seem to be working out for me
Just for the record physically connecting over the network to the Garuda PC isn’t the problem, that works just fine as you can see here:
╭─fenris@fenris in /mnt/veracrypt1/Videos as 🧙 took 109ms
╰─λ sudo systemctl status xrdp
● xrdp.service - xrdp daemon
Loaded: loaded (/usr/lib/systemd/system/xrdp.service; enabled; preset: dis>
Active: active (running) since Mon 2024-04-22 14:13:59 CDT; 17s ago
Docs: man:xrdp(8)
man:xrdp.ini(5)
Main PID: 1261456 (xrdp)
Tasks: 1 (limit: 18869)
Memory: 1.7M (peak: 1.9M)
CPU: 25ms
CGroup: /system.slice/xrdp.service
└─1261456 /usr/bin/xrdp --nodaemon
Apr 22 14:13:59 fenris-minispro12 systemd[1]: Starting xrdp daemon...
Apr 22 14:13:59 fenris-minispro12 (xrdp)[1261456]: xrdp.service: Referenced but>
Apr 22 14:13:59 fenris-minispro12 systemd[1]: Started xrdp daemon.
Apr 22 14:13:59 fenris-minispro12 xrdp[1261456]: [INFO ] starting xrdp with pid>
Apr 22 14:13:59 fenris-minispro12 xrdp[1261456]: [INFO ] address [0.0.0.0] port>
Apr 22 14:13:59 fenris-minispro12 xrdp[1261456]: [INFO ] listening to port 3389>
Apr 22 14:13:59 fenris-minispro12 xrdp[1261456]: [INFO ] xrdp_listen_pp done
I also don’t have UFW installed so there is no ports being blocked. Its like XFCE isn’t accepting the session login for what ever reason and I ran out of things to try and fix this issue
Also, I don’t know how to categorise this topic cause I can’t tell if this is a Garuda issue in general or an XFCE4 problem
