Hello All,
Running into an issue with not being able to select 120 Hz via HDMI 2.1 on Xorg though this does work without issue when on wayland. I had a similar problem when using gnome under Fedora and stuck with wayland though it seems to be a little more buggy under KDE.
I attempted to manually add a mode via xrandr for 4k 120hz which does give me the option to switch to 120 in KDE display settings. Though even when changed the refresh rate never changes past 60.
Attempted to do some searching around on the web but information seems to be very vague on what the issue could be when using HDMI 2.1 via Xorg. Again which is all very strange because under wayland 4k 120Hz just works with no interacted needed. So coming here to see if it's even possible to get 4k 120 Hz on Xorg via HDMI 2.1 and make sure I'm currently troubleshooting to a dead end.
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d66e9fb6-0a73-4164-8ef7-a1b901a42447
rw [email protected] quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Console: pty pts/0 DM: SDDM Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 2403 date: 10/28/2021
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4003 high: 5080 min/max: 800/5100 scaling: driver: intel_pstate
governor: performance cores: 1: 5080 2: 5008 3: 2047 4: 4801 5: 4720 6: 3842 7: 1458 8: 4715
9: 2707 10: 4714 11: 4926 12: 4800 13: 4801 14: 922 15: 4802 16: 4718 bogomips: 121596
Type: itlb_multihit status: KVM: Split huge pages
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire driver: amdgpu
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: web server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1 compositor: kwin_x11 driver:
X: loaded: amdgpu gpu: amdgpu tty: 198x56
Monitor-1: HDMI-A-1 model: Sony TV 30 serial: <filter> built: 2021 res: 3840x2160 dpi: 80
gamma: 1.2 size: 1218x685mm (47.95x26.97") diag: 1397mm (55") ratio: 16:9 modes: max: 3840x2160
min: 640x480
Message: GL data unavailable in console. Try -G --display
Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 71:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp113s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Linksys Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-10:4
chip-ID: 13b1:0041 class-ID: 0000 serial: <filter>
IF: enp0s20f0u10 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: macvtap0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-12:5
chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 5.03 TiB used: 1.68 TiB (33.3%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: MZVLW512HMJP-000L7 size: 476.94 GiB
rev: 7L7QCXY7 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Sabrent model: Rocket nano size: 476.94 GiB
rev: RKT301.3 temp: 26.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
rev: 2B2QEXE7 temp: 32.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: BB6Q
ID-5: /dev/sdb maj-min: 8:16 vendor: Toshiba model: THNSNJ256GCSU size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0101
ID-6: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: ST2000LM007-1R8174
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: HDD rpm: 5400 serial: <filter>
rev: 1053 scheme: MBR
ID-7: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: External USB 3.0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 5438 scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 221.48 GiB (23.8%) fs: btrfs
dev: /dev/nvme2n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/nvme2n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 221.48 GiB (23.8%)
fs: btrfs dev: /dev/nvme2n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 221.48 GiB (23.8%)
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 221.48 GiB (23.8%)
ID-1: swap-1 type: zram size: 31.18 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 35.0 C mem: 34.0 C
Processes: 356 Uptime: 1h 9m wakeups: 5 Memory: 31.18 GiB used: 18.8 GiB (60.3%) Init: systemd
v: 250 tool: systemctl Compilers: gcc: 11.2.0 Packages: 1737 pacman: 1731 lib: 513 flatpak: 6
Shell: Bash v: 5.1.16 running-in: pty pts/0 inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-04-23
Last full system update: 2022-04-24
