Xone stick not working anymore
Hello again, until some days ago everything was working fine but now,
i've got some usb thing problems, and one of them seems the xone stick for the controllers isn't working anymore, i allready tried different kernels/usb slots and to reinstall the xone-dkms and firmwaredongle via octopi....
[email protected] in ~
╰─λ garuda-inxi
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b3328148-480b-42c9-9425-ff822289ea26 rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm:
1: GDM v: 44.1 note: stopped 2: SDDM Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1410
date: 03/17/2023
Device-1: hidpp_battery_0 model: Logitech G604 Wireless GaG604 Wirel
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
Device-2: hidpp_battery_1 model: Logitech Wireless KeyboarWirele
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4565 high: 5490 min/max: 3000/5733 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4700 2: 4700
3: 4700 4: 4700 5: 3802 6: 4700 7: 3593 8: 4700 9: 4700 10: 4700 11: 4700
12: 4700 13: 4700 14: 4700 15: 4700 16: 3802 17: 4700 18: 4700 19: 4700
20: 4700 21: 4700 22: 3593 23: 4700 24: 5490 bogomips: 225172
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: ASUSTeK
status: current (as of 2023-05) arch: Ampere code: GAxxx
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2216 class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,HDMI-A-1
bus-ID: 0d:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 60.0 C
gpu: nvidia,amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 92 s-size: 707x393mm (27.83x15.47")
s-diag: 809mm (31.85")
Monitor-1: DP-2 res: 2560x1440 hz: 60 dpi: 93
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
3080/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0d:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
Device-4: Logitech [G533 Wireless Headset Dongle]
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 046d:0a66 class-ID: 0300
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api with: aoss
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: N/A
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:10
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Local Storage: total: 8.79 TiB used: 1.69 TiB (19.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: OWC model: Aura P12 Pro 2.0TB
size: 1.75 TiB block-size: physical: 4096 B logical: 4096 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM15.1 temp: 30.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 66.8 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: MBR
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 020 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SD8SBBU240G1122
tech: SSD serial: <filter> fw-rev: 6000 scheme: MBR
ID-7: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD40EMRX-82UZ0N0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1021 scheme: GPT
used: 69.27 GiB (14.9%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 30.5 GiB used: 130 MiB (0.4%) priority: 100
System Temperatures: cpu: 72.8 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 55 C fan: 53% device: amdgpu
temp: 60.0 C
Processes: 519 Uptime: 2h 1m wakeups: 307 Memory: available: 30.5 GiB
used: 5.72 GiB (18.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1875
libs: 557 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-04-15
Last full system update: 2023-05-16
╭─[email protected] in ~ took 1s
im not sure if these are separated problems or more about the usb part ....
