inxi -Faz
System: Kernel: 5.14.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=37d276fe-853f-4e5b-b53d-a0d7d9cbb872 rw
[email protected] rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
splash
Desktop: N/A vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: TOSHIBA product: Satellite P875 v: PSPLEU-048003 serial: <filter>
Mobo: TOSHIBA model: Portable PC v: MP serial: <filter> UEFI: Insyde v: 6.30 date: 01/17/2013
Battery: ID-1: BAT0 charge: 51.4 Wh (85.0%) condition: 60.5/71.3 Wh (84.8%) volts: 10.8 min: 10.8 model: PA5024U-1BRS
type: Li-ion serial: <filter> status: Charging
CPU: Info: Quad Core model: Intel Core i7-3630QM bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 cache: L2: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38311
Speed: 3294 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 3294 2: 1632 3: 3222 4: 3030 5: 1445 6: 3247 7: 3291
8: 3292
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Toshiba driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Importek TOSHIBA Web Camera - HD type: USB driver: uvcvideo bus-ID: 1-1.3:3 chip-ID: 10f1:1a46
class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2") s-diag: 1052mm (41.4")
Monitor-1: LVDS1 res: 1920x1080 hz: 60 dpi: 128 size: 380x210mm (15.0x8.3") diag: 434mm (17.1")
Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 81 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.2.2 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Toshiba driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Device-2: Plantronics Plantronics Blackwire 3210 Series type: USB driver: plantronics,snd-usb-audio,usbhid
bus-ID: 3-1:2 chip-ID: 047f:c055 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.14.7-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Qualcomm Atheros AR8162 Fast Ethernet vendor: Toshiba driver: alx v: kernel port: 2000 bus-ID: 01:00.0
chip-ID: 1969:1090 class-ID: 0200
Device-2: Intel Centrino Wireless-N 2200 driver: iwlwifi v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 8086:0890
Drives: Local Storage: total: 1.2 TiB used: 107.59 GiB (8.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD3200BEKT-60PVMT0 size: 298.09 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: 1A01 scheme: MBR
Partition: ID-1: / raw-size: 446.92 GiB size: 446.92 GiB (100.00%) used: 107.56 GiB (24.1%) fs: btrfs dev: /dev/sda4
maj-min: 8:4
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 23.7 MiB (9.3%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 446.92 GiB size: 446.92 GiB (100.00%) used: 107.56 GiB (24.1%) fs: btrfs dev: /dev/sda4
maj-min: 8:4
ID-4: /var/log raw-size: 446.92 GiB size: 446.92 GiB (100.00%) used: 107.56 GiB (24.1%) fs: btrfs dev: /dev/sda4
maj-min: 8:4
ID-5: /var/tmp raw-size: 446.92 GiB size: 446.92 GiB (100.00%) used: 107.56 GiB (24.1%) fs: btrfs dev: /dev/sda4
maj-min: 8:4
ID-1: swap-1 type: partition size: 1.78 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda6 maj-min: 8:6
ID-2: swap-2 type: zram size: 11.58 GiB used: 2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 53.0 C mobo: N/A
Info: Processes: 252 Uptime: 14m wakeups: 1 Memory: 11.58 GiB used: 2.05 GiB (17.7%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 2541 lib: 491 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: alacritty inxi: 3.3.06
Hello,
I am using Xmonad with Garuda and I need a script to run every time I boot my machine to set up my dual monitor setup. I have the script already, but I am unsure where to put it so it will be run on boot. I tried putting it in .profile, as well as in my StartupHook in xmonad.hs, but it is still not running. Ideally it would also run before nitrogen is called to set the wallpaper. Where is a location that is read/executed on boot or log in?
