Xinput controller
i have a steel series controller (xinput) that works on windows fine but when i plug it in in this laptop that i have garuda installed on its like it dont exist. my ps controller work with linux but it has stick drift bad id like to use the steel series controller working with this laptop. i travel alot with this laptop and i would love to have the controller work with either the dongle or wired either is fine.
Kernel: 6.6.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    root=UUID=6f8cbe6c-a0f9-4f09-8cd1-a005d0e0fe60 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
  Mobo: HP model: 86D4 v: 96.45 serial: <superuser required> UEFI: AMI
    v: F.13 date: 03/03/2022
  ID-1: BAT0 charge: 43.6 Wh (100.0%) condition: 43.6/43.6 Wh (100.0%)
    volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: N/A status: full cycles: 392
  Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 2286 high: 2771 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 2769 2: 2100
    3: 2766 4: 2771 5: 1249 6: 2439 7: 2100 8: 2100 bogomips: 33535
  Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q]
    vendor: Hewlett-Packard driver: nvidia v: 545.29.06
    2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: none empty: HDMI-A-1
    bus-ID: 01:00.0 chip-ID: 10de:1c91 class-ID: 0300
  Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
    ports: active: eDP-1 empty: HDMI-A-2 bus-ID: 05:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 52.0 C
  Device-3: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2
    chip-ID: 30c9:0013 class-ID: 0e02 serial: <filter>
    gpu: nvidia,amdgpu display-ID: 0
  Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven
    LLVM 16.0.6 DRM 3.54 6.6.6-zen1-1-zen) device-ID: 1002:15d8
  API: Vulkan v: 1.3.269 layers: 10 device: 0 type: integrated-gpu name: AMD
    Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1
    type: discrete-gpu name: NVIDIA GeForce GTX 1050 driver: nvidia
    v: 545.29.06 device-ID: 10de:1c91 surfaces: xcb,xlib,wayland device: 2
    type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
  Device-1: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
    driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  API: ALSA v: k6.6.6-zen1-1-zen status: kernel-api with: aoss
    vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
    vendor: Hewlett-Packard Pavilion Laptop 15-ec0xxx driver: r8169 v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b00c
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 238.47 GiB used: 74.39 GiB (31.2%)
    model: MZVLQ256HAJD-000H1 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: HPS2NFXV temp: 31.9 C scheme: GPT
    used: 74.39 GiB (31.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 13.52 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 52.2 C mobo: N/A gpu: amdgpu temp: 52.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Processes: 304 Uptime: 2m wakeups: 0 Memory: total: 16 GiB note: est.
  available: 13.53 GiB used: 2.88 GiB (21.3%) Init: systemd v: 255
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1904
  pm: pacman pkgs: 1872 libs: 537 tools: octopi,paru pm: flatpak pkgs: 32
  Shell: Bash v: 5.2.21 running-in: octopi inxi: 3.3.31
Garuda (2.6.21-1):
  System install date:     2023-11-20
  Last full system update: 2023-12-16
Having just had a problem with garuda not recognizing my xbox controller, but working fine with my PS4 controller, I’ll recommend what I had to do
Also, for the garuda-inxi, so long as you have a gui, you can just highlight it with your mouse cursor, right click, copy, and then paste normally. ctrl+c doesn’t work for copying in a terminal.
ok i ran sudo pacman -Syu linux, if this is a stupid question i apologize how do i uninstalled the xone-dkms-git package. im only like a couple week into using garuda its an awesome distro for my first linux.
I don’t know if you have the git version or not, so first search which you have installed with
pacman -Ss xone
and you uninstall packages with -R
sudo pacman -R *insert which xone package you have*
and follow with
sudo pacman -S *the xone package you had*
I use the git version because it downloads and builds the version directly from github as far as I’m aware, but I imagine the official arch package doesn’t lag far behind, I believe they’re both the same at the moment.
ok i uninstalled then reinstalled still nothing. i tried loading up gzdoom and it wouldnt pick it up. i appreciate your help im not sure what to do beyond that. i might just go get another ps4 controller to save the hassle. does ps5 controllers work too or is it strictly ps4 controllers?
When you plug in the controller does it light up / have some form of confirmation that its been connected? if so could you run
lsusb
and we can see how it appears to the system
yeah it says its recognizes it on bus 001 device 006. does that mean its working then? if so you think gzdoom might be bugged
Could you copy the entire line? there are other things that could be tried, all that means is that your system does recognize something was plugged in but I’d like the description of what it believe it is.
Bus 005 Device 017: ID 045e:02ea Microsoft Corp. Xbox One Controller
is how it shows my xbox controller for instance
bus 001 device 006: ID: 1038:1431 steelseries aps steelseries stratus duo
Sorry i couldnt copy it i just typed it
thank for helping me out with this holidays are coming and i need to figure this out before then. i try it on both gzdoom and ppsspp, it didnt work on either
The two things I would suggest attempting, in order is installing xpadneo if it isn’t already
sudo pacman -S xpadneo-dkms
If that one doesn’t work, the last driver I have in mind is the generic xinput driver
sudo pacman -S xbox-generic-controller
I would also confirm that your -Syu linux installed the necessary header files
sudo pacman -S linux-headers
it still isnt working, i remember installing all the ones at the bottom of garuda gamer awhile back, do you think i should unstall them?
Those are the same ones you would install with the terminal, just through a GUI, I admit that I am newer to linux than most probably are on these forums, but the more advanced users tend to not respond if you can’t get your garuda-inxi posted, have you attempted a reboot at all while installing the packages?
ill try restarting and see if that helps
    desc: 1x4 MiB
    inactive: device-2
    class-ID: 0480
Garuda (2.6.21-1):
i figured out how to copy that
If you can, edit it and put three ~ above and below the output, it’ll make it appear in a scrollable box that looks a lot nicer, and they’d probably want it in the original post
thanks again for your help, hopefully someone knows how i can fix this
Try this ```
sudo systemctl enable --now xboxdrv.service
That’s right, Ctrl+C is something else in most terminals (stops a running process). Depending on the terminal, you can usually copy with Ctrl+Shift+C.
Or, highlight the text and “click” with the scroll wheel, to copy the highlighted text and paste where you clicked.
I’m not very knowledgeable about controllers, but if you are stuck try working through this article from ArchWiki. It’s obviously a different controller, but I believe it’s the same controller family. https://wiki.archlinux.org/title/Gamepad#iPEGA-9017s_and_other_Bluetooth_gamepads
