I was very curious about the Ptyxis terminal so I installed it to give it a try.
I am very impressed with it, but it has created a problem. When I open Thunar and select ‘Open terminal here’ it simply opens a terminal here…
╭─colin@Garuda in ~
╰─λ
…not in the folder being shown by Thunar.
Also, if I select ‘Open in root terminal here’ I am asked for the password, and when I enter it nothing happens.
I have selected Ptyxis as the default terminal in ‘Default applications’ to no avail, and I spent two hours last night digging through forums for an answer, also to no avail.
Does anyone know a simple way to get Ptyxis to open in the correct location when it is opened via Thunar?
Kernel: 6.12.33-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=6b8953aa-e87b-4966-b0cc-0de1083bf910 rw rootflags=subvol=@
quiet resume=UUID=8bf075b5-c764-4fd6-a6b2-1e55d21a7a1d loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 20L50000UK v: ThinkPad T480
Mobo: LENOVO model: 20L50000UK v: SDK0J40697 WIN
part-nu: LENOVO_MT_20L5_BU_Think_FM_ThinkPad T480
uuid: <superuser required> UEFI: LENOVO v: N24ET75W (1.50 )
date: 10/30/2023
ID-1: BAT0 charge: 10.9 Wh (66.5%) condition: 16.4/24.0 Wh (68.2%)
volts: 11.3 min: 11.5 model: LGC 01AV421 type: Li-poly serial: <filter>
status: not charging cycles: 14
ID-2: BAT1 charge: 16.4 Wh (79.6%) condition: 20.6/23.9 Wh (86.0%)
volts: 12.2 min: 11.4 model: LGC 01AV490 type: Li-poly serial: <filter>
status: not charging cycles: 341
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF6
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/3400 scaling: driver: intel_pstate
8: 800 bogomips: 28808
Device-1: Intel UHD Graphics 620 vendor: Lenovo ThinkPad T480 driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Bison SunplusIT Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 5986:2113
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.16 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99")
Monitor-1: eDP-1 model: BOE Display 0x0791 built: 2017 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1920x1080
API: Vulkan v: 1.4.313 layers: 7 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (KBL GT2) driver: mesa intel v: 25.1.3-arch1.3
device-ID: 8086:5917 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.6 256 bits) driver: mesa llvmpipe v: 25.1.3-arch1.3 (LLVM
Info: Tools: api: vulkaninfo de: xfce4-display-settings
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
API: ALSA v: k6.12.33-1-lts status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-V vendor: Lenovo ThinkPad T480 driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: N/A
Local Storage: total: 238.47 GiB used: 11.37 GiB (4.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF256G8L
lanes: 4 tech: SSD serial: <filter> fw-rev: L15P temp: 26.9 C scheme: GPT
ID-1: / raw-size: 29.3 GiB size: 29.3 GiB (100.00%) used: 10.73 GiB (36.6%)
ID-3: /home raw-size: 192.9 GiB size: 192.9 GiB (100.00%)
used: 652 MiB (0.3%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 29.3 GiB size: 29.3 GiB (100.00%)
used: 10.73 GiB (36.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 29.3 GiB size: 29.3 GiB (100.00%)
Kernel: swappiness: 30 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 15.98 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.0 C mobo: N/A
Memory: total: 16 GiB available: 15.51 GiB used: 3.48 GiB (22.4%)
Processes: 306 Power: uptime: 11h 15m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.18 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 257
Packages: 1303 pm: pacman pkgs: 1295 libs: 416 tools: paru pm: flatpak
pkgs: 8 Compilers: gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
running-in: ptyxis-agent inxi: 3.3.38
System install date: 2025-06-03
Last full system update: 2025-06-15
Windows dual boot: Probably (Run as root to verify) [ABSOLUTELY NOT!]
