Hello! I have xfce desktop manager. Is it possible to run it on wayland?
Mariusz
Kernel: 6.1.31-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b8c044ba-3855-4296-80c1-38218b0791fd rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: Compulab model: fitlet2 v: 1.31
serial: <superuser required> UEFI: American Megatrends
v: FLT2.TPM.0.46.02.01 date: 05/24/2021
Info: model: Intel Atom E3950 bits: 64 type: MCP arch: Goldmont level: v2
built: 2016 process: Intel 14nm family: 6 model-id: 0x5C (92) stepping: 9
microcode: 0x48
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1992 min/max: 800/2000 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1992 2: 1992 3: 1992 4: 1992 bogomips: 12752
Device-1: Intel Apollo Lake [HD Graphics 505] driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: HDMI-A-1,HDMI-A-2 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:5a84
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: HP 25es
serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 88 gamma: 1.2
size: 553x309mm (21.77x12.17") diag: 633mm (24.9") ratio: 16:9 modes:
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: right model: HP 25es
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 88 gamma: 1.2
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: Mesa Intel HD Graphics 505 (APL
3) direct-render: Yes
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:5a98 class-ID: 0403
API: ALSA v: k6.1.31-1-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 8086:1539
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 8086:1539
Device-3: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 03:00.0 chip-ID: 8086:1539
IF-ID-1: eno1 state: down mac: <filter>
Local Storage: total: 119.24 GiB used: 25.96 GiB (21.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: BIWIN model: SSD size: 119.24 GiB
serial: <filter> fw-rev: 2A scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 25.96 GiB (21.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.4 GiB used: 19 MiB (0.3%) priority: 100
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 248 Uptime: 6h 5m wakeups: 0 Memory: available: 7.4 GiB
used: 2.98 GiB (40.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1514
libs: 419 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.27
System install date: 2023-03-10
Last full system update: 2023-05-31 ↻
