Hello! My Xbox series x wireless controller fails to connect to my Garuda Linux system. I have tried installing bunch of software such as "xpadneo", but it still doesn't work. Blueman reports the device as connected while the xbox logo on the controller is still blinking, even though blueman says it's connected.
Bluetooth on other Linux distributions have worked fine. But that doesn't seem to be the case with Garuda Linux. Thanks!
Here are my device specs:
Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=8dd75562-8579-47dd-b853-5f7e89ddb8f7 rw [email protected]
resume=UUID=77b4b1db-a844-40e0-83fb-5a85f313694d loglevel=3 ibt=off
Type: Laptop System: Acer product: Aspire A715-41G v: V1.03
Mobo: PK model: Azalea_PKS v: V1.03 serial: <superuser required>
UEFI: INSYDE v: 1.03 date: 10/26/2020
ID-1: BAT1 charge: 30.8 Wh (87.5%) condition: 35.2/53.0 Wh (66.4%)
volts: 16.4 min: 15.4 model: PANASONIC AP19B5L type: Li-ion serial: <filter>
status: charging
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2443 high: 3338 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2770 2: 2100
3: 2100 4: 2100 5: 2942 6: 3338 7: 2100 8: 2100 bogomips: 33537
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0302
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 58.0 C
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-1:2
chip-ID: 0408:a061 class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x065a built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 15.0.7 DRM 3.52 6.3.1-zen1-1-zen) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api with: aoss
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
bus-ID: 3-2.1:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 931.51 GiB used: 35.11 GiB (3.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS2230 1TB SSD
lanes: 4 type: SSD serial: <filter> rev: H220902a temp: 54.9 C scheme: GPT
ID-1: / raw-size: 916.27 GiB size: 916.27 GiB (100.00%)
used: 35.11 GiB (3.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 916.27 GiB size: 916.27 GiB (100.00%)
ID-4: /var/log raw-size: 916.27 GiB size: 916.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 916.27 GiB size: 916.27 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.59 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 14.95 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 58.0 C mobo: N/A gpu: amdgpu temp: 58.0 C
Processes: 330 Uptime: 22m wakeups: 1 Memory: 13.59 GiB
used: 3.65 GiB (26.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2252
pm: pacman pkgs: 2233 libs: 548 tools: gnome-software,octopi,paru,yay
pm: flatpak pkgs: 16 pm: snap pkgs: 3 Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date: 2023-05-03
Last full system update: 2023-05-07 ↻
