Hello,
I'm trying to pair my Xbox Series Controller with bluetooth. After pairing the controller, the LED still flashes and bluetoothctl outputs Connected: Yes and Connected: No repeatedly! It seems that it pairs successfully but it cannot connect correctly. I'm sure that the controller is working because it pairs with Bluetooth on both Android and Windows.
I've tried:
Disabling ERTM with 'echo 1 > /sys/module/bluetooth/parameters/disable_ertm' as root
Uninstalling KDE Connect and trying to pair/connect again
Deleting bluetooth service cache with '/var/lib/bluetooth/*/cache' and rebooting
Updating the controller with the 'Xbox Accessories App'
Kernel: 5.14.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=55715951-8547-4496-ba16-8216fa919b8e rw rootflags=subvol=@ quiet
resume=UUID=5fade6ba-8994-4147-bfb0-bc8276b3e1b8 loglevel=3 amd_iommu=on
video=efifb:off
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B450M S2H v: N/A serial: <filter>
Mobo: Gigabyte model: B450M S2H v: x.x serial: <filter>
UEFI: American Megatrends LLC. v: F62b date: 09/06/2021
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming Mouse
status: Discharging
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 100617
Speed: 4192 MHz min/max: 2200/4200 MHz boost: disabled Core speeds (MHz): 1: 4192
2: 4194 3: 4192 4: 4192 5: 4192 6: 4192 7: 4192 8: 4192 9: 4192 10: 4192 11: 4192
12: 4192
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 0a:00.0 chip-ID: 10de:1f08 class-ID: 0300
Display: x11 server: X.org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74
direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 0a:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: kernel port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.27 TiB used: 789.72 GiB (34.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM961 NVMe 256GB
lanes: 4 type: SSD serial: <filter> rev: CXB73D1Q temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
type: HDD rpm: 7200 serial: <filter> rev: 1A02 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Patriot model: Burst size: 223.57 GiB
serial: <filter> rev: 61.3 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HTS541010A9E680
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: A5M0 scheme: MBR
ID-1: / raw-size: 221.01 GiB size: 221.01 GiB (100.00%) used: 119.81 GiB (54.2%)
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 221.01 GiB size: 221.01 GiB (100.00%)
used: 119.81 GiB (54.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 221.01 GiB size: 221.01 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.01 GiB size: 221.01 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.2 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.57 GiB used: 256 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.1 C mobo: 16.8 C gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
Processes: 392 Uptime: 21m wakeups: 3 Memory: 15.57 GiB used: 5.44 GiB (34.9%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1162
lib: 326 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.06~~~
filo
10 October 2021 15:49
2
Hi there, welcome.
Could you please provide your inxi -Faz as per new topic template, formatted with ~~~ before and after the text block?
video=efifb:off
status: Discharging
bogomips: 100617
12: 4192
direct render: Yes
filo
10 October 2021 16:17
4
Maybe you could try removing the controller from paired devices in windows, should this be a dual boot issue…
I’m leaving you also the link to a recent interesting bluetooth thread.
It is 99% other stuff… Just try to give a look if you want.
Alright, it's been resolved! The solution was to install bluez-git, delete /var/lib/bluetooth and, most importantly drain the power from my PC. I tried the first two steps a while back, which was detailed in a different thread. I never drained the power because most people said that their issue was resolved after the first two steps, so I figured there was no need.
But I found one other person who, like me, was only able to finalize those changes after draining the power. I'm not entirely sure …
I'm not dual-booting, I'm running windows on a VM
I'll try this and I'll report back.
"Use a Windows 10 computer on the same Bluetooth adapter to pair with the controller. It must absolutly be on
the same Bluetooth adapter, i.e. the same computer (can be inside a virtual machine with Bluetooth passthrough)
if it's an internal Bluetooth adapter, or the same Bluetooth dongle. Then, you can get the pairing keys and
install them within your Linux Bluetooth system."
I came back and booted my PC after several hours and the controller paired successfully without changing anything. I did not update, I did not change any grub parameters, configs etc. I had already restarted sereval times when I was trying to pair and connect it before and the reboot never fixed the issue.
tbg
10 October 2021 23:33
8
I think it’s very possible Windows still has the capability of interfering with your bluetooth adapter in Linux even from a VM. You may find this an on again, off again problem if still using Windows.
Completely powering down (not a warm reboot) and removing all power sources may help in these instances. In extreme cases a BIOS reset to the factory defaults is required.
Bro
10 October 2021 23:46
9
In addition to @tbg 's suggestions, I've also had to go into my BIOS and turn Fast Boot's hardware discovery to Thorough in order to rediscover my BT adapter after a Windows 10 installation decided I didn't have one.
tbg
10 October 2021 23:51
10
Turning off Wifi and Bluetooth power saving in Windows Device Manager's "advanced" properties tab may sometimes help with this occurrence. Unfortunately, a Windows update may reset this, (so it may not be a permanent fix).
Hi...there is anything but a particular connector for the Series X/S regulators for PC. The current connector turns out only great with these fresher regulators, but it is presently in extremely short stockpile. There are outsider ones accessible that do exactly the same thing.
The Xbox 360 remote regulators utilize an alternate WIFI convention, they need their own Xbox 360 remote Gaming Receiver.
Xbox One and Series X/S regulators can be associated with PC through Bluetooth, however headsets will just work with the Xbox One connector (or an outsider form), they will not work when the regulator is associated by means of BT
system
Closed
26 October 2021 16:22
12
