I am running shadow cloud gaming on Garuda Linux x86_64
is it the shadow or my bluetooth is screwed up
my controller xbox one s show as 2 controller connect when there only one how to fix!
is ther a way around this isse
I never had this isse with fresh install Garuda Linux x86_64 before
one day turn it on and it was like this and 1 button dont work on the controller in shadow
I also made a ticket for shadow
OS: Garuda Linux x86_64
.8Xx; 8x:. Kernel: 5.10.15-120-tkg-bmq
.tt8x .d x88; Uptime: 6 mins
.@8x8 ; .db: xx@;
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Packages: 1687 (pacman)
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Shell: fish
,888S pd! Resolution: 1920x1080
8X88/ q Terminal: chromium
GBB.
x%88 d888@8@X@X@X88X@@XX @@X @8@X. CPU: Intel i7 860 (8) @ 2.801GHz
dxXd dB8b8b8B8B08bB88b998888b88x. Memory: 3224MiB / 24005MiB (
Is this creating an actual functional issue, or is it just a display problem?
Have you tired removing and re-adding the controller (e.g. removing and re-pairing)?
Have you looked at, read, or tried anything else you haven’t mentioned?
Yes I have removed it and add it back also I tried repairing it
michaelpop0:
Bluetooth dongle works properly because I tried it in another computer
michaelpop0:
i also did this command to
systemctl enable restart-bt.service
You can edit your post its not a chat its a forum
greetings SGS
SGS
17 February 2021 02:40
6
Please, read the wiki "Reporting bugs"
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
and
When start playing halo mcc my xbox one s controller some of buttons dont work for some reason.
thanks i will do that next time
SGS
17 February 2021 03:10
9
michaelpop0:
“Is this creating an actual functional issue, or is it just a display problem?”
Fine
Not fine.
@discobot help @michaelpop0 please
Hi! To find out what I can do, say @discobot display help.
I currently know how to do the following things:
@discobot start {name-of-tutorial}
Starts an interactive tutorial just for you, in a personal message. {name-of-tutorial} can be one of: tutorial, advanced tutorial.
@discobot roll 2d6
3, 6
@discobot quote
Do not overrate what you have received, nor envy others. He who envies others does not obtain peace of mind. — Buddha
@discobot fortune
You may rely on it
