Hello Garuda users.
I am a total newbie to Linux, please keep that in mind. I'm plugging the controller directly into a USB port on the back of my motherboard.
My controller used to work without issues (in Elden Ring) a month or so ago.
According to the Arch Wiki it should be natively supported, which it doesn't anymore. In Windows 10 it is recognized like usual and all buttons are working there, so I'm assuming the Micro-USB cable and controller work technically.
I have tried enabling and starting the xboxdrv.service but I get the following error:
"Failed to enable unit: Unit file xboxdrv.services.service does not exist."
When I check lsusb it does appear to be recognized:
Bus 005 Device 003: ID 045e:02e3 Microsoft Corp. Xbox One Elite Controller
Neither Steam nor the Game Controller in System Settings recognize it.
I hope anyone can help me out with this issue, I really want to ditch windows finally.
Kernel: 6.4.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=f8614fe3-0fce-4fb5-9365-182f4055f0c3 rw rootflags=subvol=@
resume=UUID=d8e950b4-97eb-44d0-90a0-d70a380335fb loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-I GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4602
date: 02/23/2023
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
Device-2: hidpp_battery_1 model: Logitech MX Master 3 for Mac
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3639 high: 4276 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4173 2: 4276
3: 3400 4: 3400 5: 3356 6: 4174 7: 3400 8: 3400 9: 3582 10: 3600 11: 3400
12: 3565 13: 3530 14: 4037 15: 3533 16: 3400 bogomips: 108804
Device-1: AMD Navi 21 [Radeon RX 6900 XT] vendor: Tul / PowerColor
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
off: HDMI-A-1 empty: DP-1,DP-2 bus-ID: 0c:00.0 chip-ID: 1002:73af
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon RX 6900 XT (navi21
LLVM 15.0.7 DRM 3.52 6.4.7-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.4.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:4 chip-ID: 8087:0029
address: <filter>
Local Storage: total: 2.69 TiB used: 752.27 GiB (27.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRS1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 24.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Crucial model: CT1000P1SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR013 temp: 40.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Sabrent model: SABRENT
size: 894.25 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 2210 scheme: GPT
ID-1: / raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
used: 752.25 GiB (83.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 25.9 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-4: /var/log raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
ID-2: swap-2 type: zram size: 31.25 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.4 C mobo: N/A gpu: amdgpu temp: 47.0 C
mem: 46.0 C
Processes: 376 Uptime: 11m wakeups: 12 Memory: total: 32 GiB
available: 31.25 GiB used: 3.86 GiB (12.4%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1869 libs: 522 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-06-30
Last full system update: 2023-07-30
