Xbox Elite Series 2 firmware update through KVM?
Kernel: 6.4.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4fdf9e35-eb8e-4181-93e8-eae07da02c42 rw rootflags=subvol=@
amd_iommu=on ibt=off
Type: Laptop System: LENOVO product: 82KC v: Lenovo V14 G2 ALC
serial: <superuser required> Chassis: type: 10 v: Lenovo V14 G2 ALC
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: GLCN46WW date: 04/29/2022
ID-1: BAT0 charge: 37.9 Wh (97.9%) condition: 38.7/38.0 Wh (101.9%)
volts: 8.2 min: 7.7 model: LGC L20L2PF0 type: Li-poly serial: <filter>
status: not charging cycles: 62
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1927 high: 2561 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2247 2: 1396
3: 1396 4: 2561 5: 1398 6: 2100 7: 1392 8: 2100 9: 2244 10: 2100 11: 2100
12: 2100 bogomips: 50305
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1
empty: none bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300 temp: 41.0 C
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:2137
class-ID: 0e02
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 506x570mm (19.92x22.44")
s-diag: 762mm (30.01")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: top model: Dell P2417H
serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
Monitor-2: eDP-1 mapped: eDP pos: primary,bottom
model: AU Optronics 0x208d built: 2019 res: 1920x1080 hz: 60 dpi: 158
gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.8-zen1-1-zen) direct-render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.8-zen1-1-zen status: kernel-api tools: N/A
vendor: Lenovo driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:c123
Local Storage: total: 476.94 GiB used: 173.6 GiB (36.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPJTJ512MEE1OWX size: 476.94 GiB block-size: physical: 512 B
fw-rev: 2.1C0628 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
used: 49.1 GiB (19.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
ID-4: /var/log raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
ID-5: /var/tmp raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
ID-1: swap-1 type: zram size: 21.37 GiB used: 14.5 MiB (0.1%)
System Temperatures: cpu: 47.1 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 373 Uptime: 4h 8m wakeups: 1 Memory: total: 24 GiB note: est.
available: 21.37 GiB used: 5.53 GiB (25.9%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1505 libs: 384 tools: octopi,paru,yay Shell: fish
v: 3.6.1 running-in: yakuake inxi: 3.3.28
System install date:     2023-06-28
Last full system update: 2023-08-08 ↻
Hi,
I have an issue related to my Xbox Elite Series 2 controller. I want to do a firmware update for it using the w11 Xbox Accessories app, like mentioned in the Arch wiki, however I'm having trouble getting my controller to be recognized by the w11 VM.
It connects just fine to my host OS, both via Bluetooth and via USB cable, but I haven't been able to pass it through to the VM. The farthest I've got has been by connecting the controller via cable and adding a new USB host device in my virtual machine settings. The device shows up in Windows' Device Manager, but the Xbox Accessories app doesn't detect it, and neither does https://gamepad-tester.com on the guest machine.
I don't know if this is relevant or not, but I also installed xpadneo on my host before trying to pass my controller through to the VM.
I tried looking this up, but I haven't been able to find solutions, or at least not ones that I understand how to do myself.
Is there something I'm missing?
Thanks
