I've recently switched from Pop OS to Garuda because I wanted to just try another distro. Garuda looked really nice and the KDE Gaming image feels so smooth in the UI. However, I cannot get either my XBox 360 Wireless nor the wired controller to work. In Pop OS, they worked right out of the box with no issue.
In my case, the 4 lights around the Logo button just flash. Sometimes, it might register finally but when I try to use them in any Steam games, the controller is not working in the games at all.
In Pop OS, I had no issue what-so-ever and never had to do anything special to get it to work, so I'm not sure what is going on with Garuda. I really want to stay with Garuda, but I might have to switch back to Pop OS if I can't get the controllers to work.
Doing lsusb, I can see the XBox 360 receiver is there but for whatever reason, it just won't work.
I've searched and can't find a solution to this at all. As I stated, it works in Pop OS but not Garuda.
Here is my output from garuda-inxi:
Kernel: 6.1.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=20834898-fd28-4c96-aced-9b0c2862486a rw [email protected]
loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
Mobo: Gigabyte model: B450M DS3H-CF serial: <superuser required>
UEFI: American Megatrends LLC. v: F63b date: 05/11/2022
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3967 high: 3968 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3967 2: 3968
3: 3967 4: 3968 5: 3968 6: 3968 7: 3967 8: 3967 9: 3967 10: 3967 11: 3967
12: 3967 bogomips: 86237
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: ASUSTeK driver: nvidia
v: 525.78.01 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 06:00.0 chip-ID: 10de:2184 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 101 s-size: 1450x272mm (57.09x10.71")
s-diag: 1475mm (58.08")
Monitor-1: DP-0 pos: primary,center res: 1920x1080 hz: 75 dpi: 85
size: 576x324mm (22.68x12.76") diag: 661mm (26.02") modes: N/A
Monitor-2: DVI-D-0 pos: left res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.74x10.55") diag: 546mm (21.51") modes: N/A
Monitor-3: HDMI-0 pos: right res: 1920x1080 hz: 75 dpi: 85
API: OpenGL v: 4.6.0 NVIDIA 525.78.01 renderer: NVIDIA GeForce GTX
1660/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 1-1:2 v: kernel chip-ID: 0d8c:0012 pcie:
gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16 bus-ID: 06:00.1
chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media USB Audio Device type: USB
Sound API: ALSA v: k6.1.6-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: N/A
bus-ID: 1-5:5 chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
Local Storage: total: 7.07 TiB used: 2.27 TiB (32.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 91.3
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS5C3030ALA630
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5700 serial: <filter> rev: A580 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDS723020BLA642
type: HDD rpm: 7200 serial: <filter> rev: A5C0 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: HD103SI
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1118 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: JMicron Tech model: N/A
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0509 scheme: MBR
ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: Generic
model: USB SD Reader size: 14.9 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-7: /dev/sdg maj-min: 8:96 type: USB vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: HDD
rpm: 5400 serial: <filter> scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
used: 14.53 GiB (29.7%) fs: btrfs dev: /dev/sdc3 maj-min: 8:35
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 44.54 GiB (2.5%) fs: btrfs dev: /dev/sdc4 maj-min: 8:36
ID-4: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 16 MiB (0.1%) priority: 100
System Temperatures: cpu: 88.1 C mobo: 36.0 C gpu: nvidia temp: 49 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 359 Uptime: 1h 5m wakeups: 0 Memory: 15.54 GiB
used: 7.74 GiB (49.8%) Init: systemd v: 252 default: graphical
pkgs: 1860 libs: 514 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-15
Last full system update: 2023-01-15 ↻
