Xbox 360 Controller
Hello,
I started a Retroarch Discord converstaion here on the topic, hoping they could help me. I can play N64 games through the Mupen core, however I cannot get my Xbox 360 controller to work. Tried multiple settings. Log file has an error message:
[ERROR] [Wayland]: Failed to connect to Wayland server.
and what looks to be controller related line outputs:
[INFO] [udev]: Pad #0 (/dev/input/event3) supports 0 force feedback effects. [INFO] [udev]: Pad #1 (/dev/input/event20) supports 0 force feedback effects. [INFO] [udev]: Pad #2 (/dev/input/event21) supports 0 force feedback effects.
Also, Xbox 360 controller is working perfectly in non-Retroarch related games.
I'm also already in the 'input' group as a user. Makes me think it is either Wayland or udev (although I cycled through other input drivers). I also received the picture (on Discord) and have tried to configure the Xbox 360 controller in port #1 as well, while making the ASRock and Xbox Gamepad
marked as disabled. I don't understand why these are showing up as there is only the one Xbox 360 controller connected to my PC. Any help would be appreciated.
Thanks,
Zonsopkomst
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=404607fd-df6a-4caf-809e-3ed3d90d8595 rw rootflags=subvol=@
quiet
cryptdevice=UUID=b11dc19b-73d3-4cce-b4e9-54931a0c1dea:luks-b11dc19b-73d3-4cce-b4e9-54931a0c1dea
root=/dev/mapper/luks-b11dc19b-73d3-4cce-b4e9-54931a0c1dea splash
Type: Desktop Mobo: ASRock model: H570M Pro4 serial: <superuser required>
UEFI: American Megatrends LLC. v: P1.50 date: 04/13/2021
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 35%
rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
status: Discharging
Info: model: Intel Core i5-10400 bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 3 microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4091 high: 4100 min/max: 800/4300 scaling:
driver: intel_pstate governor: performance cores: 1: 4098 2: 4097 3: 4100
4: 4097 5: 4087 6: 4100 7: 4100 8: 4092 9: 4074 10: 4058 11: 4096
12: 4100 bogomips: 69597
vendor: Gigabyte driver: amdgpu v: kernel bus-ID: 01:00.0
Device-2: Logitech HD Webcam B910 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.1:4 chip-ID: 046d:0823
Device-3: Logitech HD Webcam B910 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.2:7 chip-ID: 046d:0823
Device-4: Logitech HD Webcam B910 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3:3 chip-ID: 046d:0823
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.42.0
5.15.13-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.4 direct render: Yes
Device-1: Intel vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-5: Logitech HD Webcam B910 type: USB
Sound Server-1: ALSA v: k5.15.13-zen1-1-zen running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-5: PipeWire v: 0.3.43 running: yes
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
Local Storage: total: 1.84 TiB used: 306.04 GiB (16.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: TM8PS7001T
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: ST1000LM024 HN-M101MBB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 0608 scheme: MBR
used: 306.04 GiB (32.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b11dc19b-73d3-4cce-b4e9-54931a0c1dea
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 15.5 GiB used: 24.5 MiB (0.2%)
System Temperatures: cpu: 34.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 733
Processes: 379 Uptime: 4h 15m wakeups: 36 Memory: 15.5 GiB
used: 4.57 GiB (29.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1952 lib: 540 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
Have you tried the xboxdrv driver? It's worth a shot. :man_shrugging:
I have used XBox 360 wired controller across many Linux distros such as Elementary, Linux Mint, Kubuntu and now Garuda Linux.
Our only difference is one thing, I use Xorg which is universally supported. I still consider Wayland as a wild west when it comes to application support. Maybe that will change once Valve releases their Steamdeck to the public and provides better support (as it comes with Wayland only by default.)
Given the controller works in games other than Retroarch it would seem the issue is with Retroarch rather than something in Garuda itself - perhaps, as Maynne suggests, something to do with Wayland.
People can’t access links to Discord posts unless they’re in that server, and it also hides it from the public web which makes it much less useful for pretty much everyone. (I have a dim opinion of Discord - it sets out to specifically create closed communities.)
It looks like folks have experienced issues with this controller on Wayland for a while; this thread goes back to 2017.
Toward the bottom of the discussion a fix that worked for a few people is laid out. It involves blacklisting the xpad kernel module and running xboxdrv instead. It might be worth a shot if your Discord stuff doesn't turn up a fix.
Since your system isn't fully update to date, you might have a RetroArch version that is suffering from the bug outlined here: Controllers not found steam/linux - r/RetroArch
update your system and you should have v 1.9.14 of RetroArch, then try resetting the controls.
Hi All,
Thanks for the responses. I had some other items come up and must have not setup this account for notifications via email, so apologies for the delay. As BluishHumility stated, I tried updating the xboxdrv, but still had the same problem. I also uninstalled and reinstalled Retroarch. I cycled through most of the settings in Retroarch and set the input drivers to sdl2 and udev and finally back to x. I really don't know what changed, but I the Xbox 360 controller inexplicably works. I wish I learned something that I could share, but sadly I do not know what caused the controller to work. I've tried Retroarch on three different systems now and it seems finicky to me at least.
Anyways, thanks for all the suggestions!
Zonsopkomst
I'm not a fan of Discord either. But it was the route for assistance with Retroarch so I thought I would post it here for reference.
I think I have a separate issue on updating my system, as I was using Garuda Assitant to manage updates (this is my media PC which I don't want to maintain, just for fun).
Hopefully so!
