X11 not an option on SDDM lock screen
X11 is no longer showing in the drop-down on SDDM. In fact the drop-down is not showing at all on the default Garuda SDDM screen. Using one of the others, I can see the drop-down but Wayland is the only option available.
Xorg is still installed as far as I can tell. There are a number of xorg-xxxx packages installed. I’d love to use Wayland but I have too many Nvidia issues that I don’t have time to resolve at the moment.
What’s my next step to check? I didn’t miss X11 being removed in an update, did I?
  Kernel: 6.15.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=949f120b-6fda-47c9-8302-5cc39177e07b rw rootflags=subvol=@
    rd.luks.uuid=9d3e9398-8c28-4e4e-94ce-6270ff9d82ac loglevel=3 pci=noaer
  Desktop: KDE Plasma v: 6.4.2 tk: Qt v: N/A info: frameworks v: 6.16.0
  Type: Laptop System: Micro-Star product: GE75 Raider 10SF v: REV:1.0
  Mobo: Micro-Star model: MS-17E9 v: REV:1.0 serial: <superuser required>
    part-nu: 17E9.1 uuid: <superuser required> UEFI: American Megatrends
    v: E17E9IMS.10D date: 11/17/2020
  ID-1: BAT1 charge: 24.4 Wh (59.8%) condition: 40.8/51.6 Wh (79.2%)
    volts: 11.1 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: not charging
  Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 2 microcode: 0x100
  Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
  Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh]
    vendor: Micro-Star MSI driver: nvidia v: 575.64.03
    alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current (as
    of 2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:1f14 class-ID: 0300
  Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:5 chip-ID: 5986:211c
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia gpu: i915
    display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x176e built: 2019 res:
    mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 128 gamma: 1.2
    size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9
    modes: 1920x1080
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.03
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
  API: Vulkan v: 1.4.313 layers: 15 device: 0 type: integrated-gpu
    name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 25.1.5-arch1.1
    device-ID: 8086:9bc4 surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 2070 driver: nvidia v: 575.64.03
    device-ID: 10de:1f14 surfaces: N/A device: 2 type: cpu name: llvmpipe
    (LLVM 20.1.7 256 bits) driver: mesa llvmpipe v: 25.1.5-arch1.1 (LLVM
    20.1.7) device-ID: 10005:0000 surfaces: N/A
  Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
  Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  API: ALSA v: k6.15.6-zen1-1-zen status: kernel-api with: aoss
  Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
    vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 1969:e0b1 class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0026
  Local Storage: total: 1.84 TiB used: 562.94 GiB (29.9%)
    model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: GXA7301Q temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
    used: 562.94 GiB (59.0%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-9d3e9398-8c28-4e4e-94ce-6270ff9d82ac
    used: 776 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 54.0 C pch: 44.0 C mobo: N/A
  Memory: total: 32 GiB available: 31.16 GiB used: 3.03 GiB (9.7%)
  Processes: 346 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.38 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1871 libs: 537 tools: octopi,paru Compilers:
    clang: 20.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
Garuda (2.7.3-1):
  System install date:     2025-03-12
  Last full system update: 2025-07-12
It has been discussed quite a few times recently, because of upstream changes you must manually install plasma-x11-session.
…huh. Thanks. I swear I searched, but seems I need to form better queries…
Mahalo!
Also checkout this page from time to time if you like to.
