Hello Garuda users.
I was using a systemd service to enable emacs server at login.
[Unit]
Description=Emacs text editor
Documentation=info:emacs man:emacs(1) https://gnu.org/software/emacs/
[Service]
Type=notify
ExecStart=/usr/bin/emacs --fg-daemon
# Emacs will exit with status 15 after having received SIGTERM, which
# is the default "KillSignal" value systemd uses to stop services.
SuccessExitStatus=15
# The location of the SSH auth socket varies by distribution, and some
# set it from PAM, so don't override by default.
# Environment=SSH_AUTH_SOCK=%t/keyring/ssh
Restart=on-failure
[Install]
WantedBy=default.target
But recently, I noticed that I couldn't start the emacsclient graphically. I could see that
emacsserver is still running and I can still use it in the tui mode.
● emacs.service - Emacs text editor
Loaded: loaded (/home/tusharhero/.config/systemd/user/emacs.service; enabled; preset: enabled)
Active: active (running) since Mon 2023-07-10 10:01:04 IST; 13min ago
Docs: info:emacs
man:emacs(1)
Main PID: 11569 (emacs)
Tasks: 2 (limit: 6951)
Memory: 175.5M
CPU: 10.855s
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/emacs.service
├─11569 /usr/bin/emacs --fg-daemon
└─11655 /usr/bin/aspell -a -m -B --encoding=utf-8
Jul 10 10:01:07 garuda emacs[11569]: Loading /home/tusharhero/.emacs.d/.cache/recentf...done
Jul 10 10:01:38 garuda emacs[11569]: [304B blob data]
Jul 10 10:01:39 garuda emacs[11569]: Invalid MIT-MAGIC-COOKIE-1 key
Jul 10 10:01:40 garuda emacs[11569]: Invalid MIT-MAGIC-COOKIE-1 key
Jul 10 10:01:41 garuda emacs[11569]: Invalid MIT-MAGIC-COOKIE-1 key
Jul 10 10:03:32 garuda emacs[11569]: Invalid MIT-MAGIC-COOKIE-1 key
Jul 10 10:03:38 garuda emacs[11569]: Invalid MIT-MAGIC-COOKIE-1 key
Jul 10 10:04:13 garuda emacs[11569]: [persp-mode] Error: Can not deactivate frame -- (wrong-type-argument frame-live-p #<dead frame F3 0x559dade46e78>)
Jul 10 10:04:30 garuda emacs[11569]: [persp-mode] Error: Can not deactivate frame -- (wrong-type-argument frame-live-p #<dead frame F4 0x559db5ca7150>)
Jul 10 10:06:25 garuda emacs[11569]: [persp-mode] Error: Can not deactivate frame -- (wrong-type-argument frame-live-p #<dead frame F5 0x559db4991400>)
If I try to run it from the terminal I get the following error.
λ emacsclient -nc
*ERROR*: Display :0 can’t be opened
From a searx search it seems like it has something to do with Xauthority.
Kernel: 6.4.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=e01c77a9-8744-4c85-afee-cef1f429bd62 rw rootflags=subvol=@
resume=UUID=f9b0b8af-d574-4661-a0d5-4e2a9f483bd3 loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5220
date: 09/12/2019
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1293 high: 1400 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1258
3: 1258 4: 1257 bogomips: 28746
ports: active: HDMI-A-1 empty: DP-1 bus-ID: 07:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 45.0 C
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) FULL HD
serial: <filter> built: 2016 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 15.0.7 DRM 3.52 6.4.1-zen2-1-zen) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK PRIME B450M-A
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.1-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter
driver: rtl8xxxu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-3:2 chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
IF: wlp1s0f0u3 state: up mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4
Local Storage: total: 1.93 TiB used: 1.36 TiB (70.6%)
model: WD20EZAZ-00GGJB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU650 size: 111.79 GiB
serial: <filter> fw-rev: 831a scheme: GPT
ID-1: / raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
used: 78.72 GiB (76.7%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
ID-4: /var/log raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
ID-5: /var/tmp raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.71 GiB used: 1.5 MiB (0.0%) priority: 100
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 44.2 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 263 Uptime: 32m wakeups: 0 Memory: available: 5.71 GiB
used: 2.58 GiB (45.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1920 libs: 411 tools: paru Shell: fish v: 3.6.1 running-in: konsole
inxi: 3.3.27
System install date: 2023-01-09
Last full system update: 2023-07-10 ↻
