Hi all,
I have a fresh installation of KDE.
Manual partitions
I set for swap partitions 12 GB, as it shows in Gparted.
but in System info it shows 17.7 GB.
Did I missed something or it is ok ?
> ╭─marko at hpenvy in ⌁
> ╰─λ inxi -Fazy
> System:
> Kernel: 5.9.11-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
> parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
> root=UUID=214ec332-14e2-41bb-b0a6-6be73b2a9c71 rw rootflags=subvol=@ quiet
> splash rd.udev.log_priority=3 vt.global_cursor_default=0
> systemd.unified_cgroup_hierarchy=1
> resume=UUID=1104e77a-7374-4db5-8618-de24099d2618 loglevel=3
> Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
> dm: SDDM Distro: Garuda Linux
> Machine:
> Type: Convertible System: HP product: HP ENVY x360 Convertible 13-ar0xxx
> v: N/A serial: <filter> Chassis: type: 31 serial: <filter>
> Mobo: HP model: 85DE v: 41.36 serial: <filter> UEFI: AMI v: F.19
> date: 12/26/2019
> Battery:
> ID-1: BAT0 charge: 50.5 Wh condition: 50.5/50.5 Wh (100%) volts: 17.3/15.4
> model: 333-2B-49-A KC04053XL type: Li-ion serial: <filter> status: Full
> Device-1: hid-0018:04F3:23B9.0004-battery model: ELAN2514:00 04F3:23B9
> serial: N/A charge: N/A status: N/A
> CPU:
> Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
> bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
> stepping: 1 microcode: 8108102 L2 cache: 2048 KiB
> flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
> bogomips: 33538
> Speed: 1273 MHz min/max: 1400/2100 MHz boost: disabled Core speeds (MHz):
> 1: 1273 2: 1472 3: 1674 4: 1352 5: 1763 6: 1668 7: 1660 8: 1354
> Vulnerabilities: Type: itlb_multihit status: Not affected
> Type: l1tf status: Not affected
> Type: mds status: Not affected
> Type: meltdown status: Not affected
> Type: spec_store_bypass
> mitigation: Speculative Store Bypass disabled via prctl and seccomp
> Type: spectre_v1
> mitigation: usercopy/swapgs barriers and __user pointer sanitization
> Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
> disabled, RSB filling
> Type: srbds status: Not affected
> Type: tsx_async_abort status: Not affected
> Graphics:
> Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
> bus ID: 04:00.0 chip ID: 1002:15d8
> Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
> bus ID: 3-1:2 chip ID: 04ca:709d
> Display: x11 server: X.org 1.20.9 compositor: kwin_x11 driver: amdgpu,ati
> unloaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
> OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.39.0
> 5.9.11-zen2-1-zen LLVM 11.0.0)
> v: 4.6 Mesa 20.2.3 direct render: Yes
> Audio:
> Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
> driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:15de
> Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
> vendor: Hewlett-Packard driver: N/A
> alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 04:00.5
> chip ID: 1022:15e2
> Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
> driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
> Sound Server: ALSA v: k5.9.11-zen2-1-zen
> Network:
> Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
> vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
> port: f000 bus ID: 02:00.0 chip ID: 10ec:b822
> IF: wlo1 state: up mac: <filter>
> Drives:
> Local Storage: total: 476.94 GiB used: 7.71 GiB (1.6%)
> SMART Message: Unable to run smartctl. Root privileges required.
> ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB
> block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
> serial: <filter> rev: HPS0 scheme: GPT
> Partition:
> ID-1: / raw size: 464.44 GiB size: 464.44 GiB (100.00%)
> used: 7.71 GiB (1.7%) fs: btrfs dev: /dev/nvme0n1p3
> ID-2: /home raw size: 464.44 GiB size: 464.44 GiB (100.00%)
> ID-3: /var/log raw size: 464.44 GiB size: 464.44 GiB (100.00%)
> ID-4: /var/tmp raw size: 464.44 GiB size: 464.44 GiB (100.00%)
> Swap:
> Kernel: swappiness: 10 (default 60) cache pressure: 75 (default 100)
> ID-1: swap-1 type: partition size: 12.00 GiB used: 0 KiB (0.0%) priority: -2
> dev: /dev/nvme0n1p2
> ID-2: swap-2 type: zram size: 734.5 MiB used: 0 KiB (0.0%) priority: 32767
> dev: /dev/zram0
> ID-3: swap-3 type: zram size: 734.5 MiB used: 0 KiB (0.0%) priority: 32767
> dev: /dev/zram1
> ID-4: swap-4 type: zram size: 734.5 MiB used: 0 KiB (0.0%) priority: 32767
> dev: /dev/zram2
> ID-5: swap-5 type: zram size: 734.5 MiB used: 0 KiB (0.0%) priority: 32767
> dev: /dev/zram3
> ID-6: swap-6 type: zram size: 734.5 MiB used: 0 KiB (0.0%) priority: 32767
> dev: /dev/zram4
> ID-7: swap-7 type: zram size: 734.5 MiB used: 0 KiB (0.0%) priority: 32767
> dev: /dev/zram5
> ID-8: swap-8 type: zram size: 734.5 MiB used: 0 KiB (0.0%) priority: 32767
> dev: /dev/zram6
> ID-9: swap-9 type: zram size: 734.5 MiB used: 0 KiB (0.0%) priority: 32767
> dev: /dev/zram7
> Sensors:
> System Temperatures: cpu: 49.0 C mobo: 45.0 C gpu: amdgpu temp: 49.0 C
> Fan Speeds (RPM): N/A
> Info:
> Processes: 294 Uptime: 10m wakeups: 949 Memory: 5.74 GiB
> used: 2.88 GiB (50.2%) Init: systemd v: 246 Compilers: gcc: 10.2.0
> clang: 11.0.0 Packages: pacman: 1015 lib: 271 Shell: fish v: 3.1.2
> running in: alacritty inxi: 3.1.09
Thanks
Edit by SGS, please use ~~~ at first and last line.
