I have downloaded i3Wm from dicrect download and SourceForge. But sha1sum and sha256sum do not match ISO
Scrap the ISO and try downloading again.
If you download a second time and it still doesn’t match, describe exactly how you are verifying the checksum with as much detail as you can; perhaps there is an issue with the method you are using.
Strange, for the last 20 years I have been doing it in the terminal with the following command sha256sun and then iso. But if I try this on this website the shasum is correct: https://emn178.github.io/online-tools/sha256_checksum.html
Now tried to go to a snapshot from the eighth of November. It is still seen the same problem in the terminal, but not on https://emn178.github.io/online-tools/sha256_checksum.html
Garuda-inxi
root=UUID=2d0983be-bc3c-4098-a113-de7515b07f2c rw rootflags=subvol=@
Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B660M DS3H DDR4 v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F20
date: 10/25/2022
Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
microcode: 0x2E
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 1206 high: 4141 min/max: 800/4800:4900:3600 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 1520 7: 4141 8: 800 9: 2251 10: 800 11: 800 12: 800
13: 800 14: 800 15: 800 16: 800 17: 800 18: 3420 19: 800 20: 800
bogomips: 84480
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
ports: active: HDMI-A-3 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Display: x11 server: X.Org v: 21.1.9 driver: X: loaded: modesetting
Monitor-1: HDMI-A-3 mapped: HDMI-3 model: ASUS VP248 serial: <filter>
built: 2019 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 770 (ADL-S
GT1) device-ID: 8086:4680 memory: 122.63 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics 770 (ADL-S GT1) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:4680 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
API: ALSA v: k6.5.9-zen2-1-zen status: kernel-api tools: alsamixergui
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Local Storage: total: 2.73 TiB used: 65.84 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBJ00101 temp: 33.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
used: 65.84 GiB (7.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 125.57 GiB used: 2 MiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 37.0 C mobo: 30.0 C
Processes: 366 Uptime: 20m wakeups: 0 Memory: total: 128 GiB note: est.
available: 125.57 GiB used: 4.58 GiB (3.7%) Init: systemd v: 254
pm: pacman pkgs: 1592 libs: 429 tools: pamac,paru Shell: Bash v: 5.2.15
running-in: terminator inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-10-30
Last full system update: 2023-11-08
Terminal output
Sha256sum
sha1sum garuda-i3-linux-zen-231029.iso
f919fe18154e265623d285dc114a319e66efdf0f garuda-i3-linux-zen-231029.iso
sha256sum garuda-i3-linux-zen-231029.iso
281563e7521c2b6fdea6b17223c7cd462da78a59b92c021255c0214196a4d849 garuda-i3-linux-zen-231029.iso
In this screenshot, you have calculated the checksum of the checksum file (not the ISO).
have entered the following in terminal and it gives an incorrect sha256sum
sha256sum garuda-i3-linux-zen-231029.iso.sha256
86e39e78c881617f8df878b16b0b77e9f2822e61b5f42b7813f785985f96d37b garuda-i3-linux-zen-231029.iso.sha256
Strange, I have tried a different ISO and here sum is correct
md5sum LXLE-Focal-Release.iso
b9b252265cd79f84d459c7c3cacdf4ef LXLE-Focal-Release.iso
type or paste code here
Just download again.
Or download direct to ventoy. Remove only over secure remove.
I have downloaded I3Wm 4 times with the same result
Now I have tried downloading Sway WM and here I can get the correct output in the terminal
I just dowload i3wm and sha256sum no problem.
Sorry, IDK what’s your problem, but something was wrong on your part.
Yes, what I am trying to say is you are calculating the checksum of the sha256 file here (instead of the ISO).
If you want to use the sha256 file like this, you need to add -c.
sha256sum -c garuda-i3-linux-zen-231029.iso.sha256
Otherwise, run against the ISO (not the checksum file).
Thanks, now shasum is correct ![]()
