Hello everyone
WPS Office suite in not opening in my Garuda Gnome. I have searched for a solution and tries something writen in Arch wiki, but it is not working. Please help.
Below is the WPS Office topic content from Arch wiki.
Use GTK+ UI
The default UI of WPS is Qt. In fact, the bundled Qt is 4.7.4, so the themes such as qtcurve cannot be loaded normally because the versions do not match. But we can change it to GTK+ and add the parameter -style gtk+ directly.
You can modify the et, wpp, and wps files in the /usr/bin/ directory and delete it (if any):
gOpt=
Then, add:
gOpt="-style=gtk+" export GTK2_RC_FILES=/usr/share/themes/Breeze/gtk-2.0/gtkrc
Below is inxi -Faz result
inxi -Faz
System: Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=623451ca-0518-4a25-b81f-110186eefb5f
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Laptop System: LENOVO product: 81W1 v: IdeaPad 3 15ADA05 serial: <filter> Chassis:
type: 10 v: IdeaPad 3 15ADA05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724WIN serial: <filter> UEFI: LENOVO v: E8CN28WW
date: 05/14/2021
Battery: ID-1: BAT0 charge: 13.8 Wh (45.8%) condition: 30.1/35.0 Wh (86.1%) volts: 7.5 min: 7.5
model: SMP L16M2PB2 type: Li-poly serial: <filter> status: Discharging cycles: 513
CPU: Info: Dual Core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109 cache: L2: 1024 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 20761
Speed: 1229 MHz min/max: 1400/2600 MHz boost: enabled Core speeds (MHz): 1: 1229 2: 1299
3: 1224 4: 1223
Graphics: Device-1: AMD Picasso vendor: Lenovo driver: amdgpu v: kernel bus-ID: 02:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-5.1:6
chip-ID: 174f:118d class-ID: 0e02 serial: <filter>
Display: wayland server: X.Org 1.21.1.2 compositor: gnome-shell driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3") s-diag: 583mm (23")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: AMD Radeon Vega 3 Graphics (RAVEN2 DRM 3.42.0 5.14.8-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.2 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 02:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x bus-ID: 02:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 02:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c822
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-6:5
chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 8 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 931.51 GiB used: 142.49 GiB (15.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
serial: <filter> rev: LFM1 scheme: GPT
Partition: ID-1: / raw-size: 146.76 GiB size: 146.76 GiB (100.00%) used: 11.72 GiB (8.0%) fs: btrfs
dev: /dev/sda9 maj-min: 8:9
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 41 MiB (42.7%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 146.76 GiB size: 146.76 GiB (100.00%) used: 11.72 GiB (8.0%) fs: btrfs
ID-4: /var/log raw-size: 146.76 GiB size: 146.76 GiB (100.00%) used: 11.72 GiB (8.0%) fs: btrfs
ID-5: /var/tmp raw-size: 146.76 GiB size: 146.76 GiB (100.00%) used: 11.72 GiB (8.0%) fs: btrfs
ID-1: swap-1 type: zram size: 9.6 GiB used: 29.3 MiB (0.3%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Info: Processes: 262 Uptime: 1d 1h 10m wakeups: 7 Memory: 9.6 GiB used: 3.1 GiB (32.3%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1210 lib: 334
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06
