With last kernel my audio and microphone became unsupported
Hello Garuda users.
with last Kernel 5.19.3 zen 1-1.my audio and microphone become unsupported (with 5.19.2 everything was ok), not seen by the system.
I was in the same situation with Manjarom with kernel 5.18 supported, 5,19 RC7 (last before been official relaeased) everyting ok, with 5.19 or 6 RC my sound and microphone are unsupported.
Using LTS kernel everything is OK. I reinstall Garuda KDE from scratch but same issue.
This is my inxi with 5.19 kernel
  Kernel: 5.19.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=8e2a14d8-9a14-4250-a281-f164d12fc9db rw rootflags=subvol=@
    quiet loglevel=3
  Desktop: KDE Plasma v: 5.25.4 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
  Type: Laptop System: HUAWEI product: KPL-W0X v: M1D
  Mobo: HUAWEI model: KPL-W0X-PCB v: M1D serial: <superuser required>
    UEFI: HUAWEI v: 1.24 date: 04/11/2022
  ID-1: BAT1 charge: 38.6 Wh (70.4%) condition: 54.8/56.3 Wh (97.3%)
    volts: 7.6 min: 7.6 model: DYNAPACK HB4593R1ECW type: Li-ion
    serial: <filter> status: not charging cycles: 109
  Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen built: 2017-19 process: GF 14nm family: 0x17 (23)
    model-id: 0x11 (17) stepping: 0 microcode: 0x8101007
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1512 high: 1600 min/max: 1600/2000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1520 2: 1600
    3: 1600 4: 1389 5: 1559 6: 1448 7: 1600 8: 1382 bogomips: 31940
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
    vendor: Huawei driver: amdgpu v: kernel arch: GCN-5 code: Vega
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 02:00.0
    chip-ID: 1002:15dd class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.4 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d4 built: 2016
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
    diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
    driver: N/A alternate: snd_hda_intel pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 02:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huawei
    snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 02:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Huawei driver: N/A
    bus-ID: 02:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.19.3-zen1-1-zen running: yes
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
  Local Storage: total: 238.47 GiB used: 8.73 GiB (3.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV8-8E256
    type: SSD serial: <filter> rev: 402 scheme: GPT
  ID-1: / raw-size: 22.24 GiB size: 22.24 GiB (100.00%) used: 8.7 GiB (39.1%)
    fs: btrfs dev: /dev/sda4 maj-min: 8:4
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 36.8 MiB
    (38.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 22.24 GiB size: 22.24 GiB (100.00%) used: 8.7 GiB
    (39.1%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
  ID-4: /var/log raw-size: 22.24 GiB size: 22.24 GiB (100.00%) used: 8.7
    GiB (39.1%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
  ID-5: /var/tmp raw-size: 22.24 GiB size: 22.24 GiB (100.00%) used: 8.7
  ID-1: swap-1 type: zram size: 6.68 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 51.6 C mobo: N/A gpu: amdgpu temp: 51.0 C
  Processes: 240 Uptime: 56m wakeups: 1 Memory: 6.68 GiB used: 1.97 GiB
  (29.5%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 931 lib: 263 Shell: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.20
Garuda (2.6.6-1):
  System install date:     2022-08-26
  Last full system update: 2022-08-26 ↻
This in INXI with LTS Kernel with sound and microphone workinh ok
  Kernel: 5.15.63-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    quiet loglevel=3
  Speed (MHz): avg: 1390 high: 1526 min/max: 1600/2000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1380 2: 1371
    3: 1370 4: 1365 5: 1371 6: 1371 7: 1373 8: 1526 bogomips: 31938
    svm
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled
    via prctl and seccomp
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user
    pointer sanitization
  Device-2: Quanta hm1091_techfront type: USB driver: uvcvideo
    bus-ID: 3-1:2 chip-ID: 0408:1020 class-ID: 0e02
    driver: snd_pci_acp3x v: kernel
    alternate: snd_rn_pci_acp3x,snd_pci_acp5x pcie: gen: 3 speed: 8 GT/s
  Sound Server-1: ALSA v: k5.15.63-1-lts running: yes
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
    v: 0.8 bus-ID: 1-2:2 chip-ID: 8087:0a2b class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
  Local Storage: total: 238.47 GiB used: 8.72 GiB (3.7%)
  SMART Message: Required tool smartctl not installed. Check
    --recommends
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B
    speed: 6.0 Gb/s type: SSD serial: <filter> rev: 402 scheme: GPT
  ID-1: / raw-size: 22.24 GiB size: 22.24 GiB (100.00%) used: 8.69 GiB
  ID-3: /home raw-size: 22.24 GiB size: 22.24 GiB (100.00%) used: 8.69
  ID-4: /var/log raw-size: 22.24 GiB size: 22.24 GiB (100.00%) used: 8.69
  ID-5: /var/tmp raw-size: 22.24 GiB size: 22.24 GiB (100.00%) used: 8.69
  Processes: 237 Uptime: 0m wakeups: 1 Memory: 6.68 GiB used: 1 GiB
  (15.0%) Init: systemd v: 251 default: graphical tool: systemctl
Garuda (2.6.6-1):
Use working kernel and format all terminal outputs. I fix it for you.
so the only way is stay some years (until kernel devs add again my hardware so probably many years and if they will add my hw again because is not sure).
So I have to uninstall zen kernel because with BRTFS it start as default on Grub,
Plus I have a issue with touchpad on last LTS kernel, i can't invert scrolling direction so fpr me is unnatural use this touchpad in this way (2 finger swipe up to page down).
I don't know if this issue fot touchpad is present on zen kernel, I will try in a minut and edit this post
UPDATE: with zen kernel touchpad work as intended 2 finger swip up is page up
So I have two choice:
a) unsupported sound and microphone using last kernel
b) half supported touchpad using lts kernel
There is a way to inform kernel devs about those issue? a link or something?
Thanks
You can choose what kernel to boot to by default by going here…
‘Garuda Welcome’ → ‘Boot Options’ → ‘Boot to’ pull down menu
Regards
I know that but as write on this setting " may cause sparse file error on BRTFS" so I prefered uninstall and stay with just LTS for the moment.
Could be that will be solved (I hope soon)
https://lore.kernel.org/all/874jy4cqok.wl-tiwai@suse.de/
https://bugzilla.suse.com/show_bug.cgi?id=1202492
Oh. I just looked at it again to see. And indeed, it says there may be sparse file errors on BTRFS.
Sorry
The solution for having sound with last kernels is to change a line in etc/default/grub file
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash amd_iommu=off"
save and then sudo update-grub
Restart and suond is working peerfectly
Is a workaround until kernel devs doesn't solve
