inxi:
Kernel: 5.18.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=21c7fde8-1bef-4f82-abc8-364dad2d6848 rw rootflags=subvol=@
resume=UUID=59131e58-a432-49f0-bae1-aebf3325230e loglevel=3 ibt=off
Desktop: Tabby info: latte-dock wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
Mobo: HP model: 8574 v: 21.17 serial: <filter> UEFI: AMI v: F.22
date: 05/03/2021
ID-1: BAT0 charge: 53.2 Wh (100.0%) condition: 53.2/53.2 Wh (100.0%)
volts: 17.3 min: 15.4 model: HP Primary type: Li-ion serial: N/A
status: full
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check
bits: 64 type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1193 high: 1201 min/max: 800/4500 base/boost: 3960/8300
scaling: driver: intel_pstate governor: powersave volts: 1.1 V
ext-clock: 100 MHz cores: 1: 1154 2: 1176 3: 1201 4: 1200 5: 1200 6: 1200
7: 1200 8: 1200 9: 1200 10: 1200 11: 1189 12: 1200 bogomips: 62399
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04ca:707f class-ID: 0e02 serial: <filter>
compositors: 1: kwin_x11 2: Tabby driver: X: loaded: nvidia gpu: nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
s-diag: 391mm (15.39")
Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.18.2-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br-db6e24092324 state: down mac: <filter>
IF-ID-3: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
bus-ID: 1-7:4 chip-ID: 8087:0029 class-ID: e001
v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.84 TiB used: 60.56 GiB (3.2%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
rev: HPS0NEXF temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 254d 11h cycles: 841
read-units: 51,119,245 [26.1 TB] written-units: 53,534,712 [27.4 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1B6Q temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 243d 23h cycles: 508
written: 2.28 TiB Pre-Fail: reallocated sector: 99 threshold: 10
ID-1: / raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
used: 60.56 GiB (6.8%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 563 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.23 GiB used: 512 KiB (0.0%)
ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.0 C pch: 54.0 C mobo: N/A gpu: nvidia
temp: 55 C
Processes: 339 Uptime: 4m wakeups: 1 Memory: 31.23 GiB
used: 4.25 GiB (13.6%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1479 lib: 369 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: tabby inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-07-24
Last full system update: 2022-06-08
Relevant software: tlp NetworkManager
Windows dual boot: Yes
Snapshots: Timeshift (maybe)
Hi community,
recently I had to switch my router, and since then, I'm having problems with Wi-Fi connection.
When I connect to the Wi-Fi, in Network Manager I can see speed up to 700 kbps, which is slowly dropping to zero. Immediately after connecting, I can load a webpage, but after that, nothing loads. Sometimes, after 5 minutes of loading, the webpage will load. I have tested it with two different routers, TP-Link and Mikrotik (Mikrotik is what I use now), and the problem is same on both. When using hotspot from my iPhone, everything is working correctly. I have performed full system update today and restarted the computer, the problem still persists.
One thing these two routers have in common is that they are using same SSID for 2.4GHz and 5GHz bands, which the previous router did not. In TP-Link I think it's called Smart Connect, in Mikrotik you just set up same SSID for both bands. I don't have any problems with this setup on Windows, iPhone, my girlfriends Android phone and tablet, Smart TV and various smart home Wi-Fi enabled devices. I have also tried to setup BSSID in Network Manager to use the 5GHz band, which shows at 100% signal strength. Wired connection is working without problem, there are no configuration errors in the Wi-Fi setup (DHCP is enabled, IP is obtained). I am also unable to ping anything, out of 100 pings sent to Google DNS only 1/10 are returned.
Any help would be greatly appreciated!
